SI 8th gen rod knock?
Old May 8, 2021
Ace J Timmons's Avatar
Ace J Timmons is an unknown quantity at this point
8th gen SI, got what could either be a rod knock or a knock sensor, how tell the difference and replace one and or the other. What all needs tool and parts wise
Old May 8, 2021
FRSam's Avatar
Click Here
Re: SI 8th gen rod knock?
Knock sensor will trigger a code. In all likelihood, it's knocking. If that's the case, there are threads covering removal and rebuilding of the engine.
Post a video of the noise if you don't mind.
Old May 18, 2021
It will be a day or two before I'm back at the shop but I will upload that video asap.
I figure it's a main rod bearing and could I replace those with removing the engine?
Old May 20, 2021
I will be at the shop tomorrow but just so you know it sounds exactly like the car 8n this video I mean spot 9n like it, reply let me know what you think and if a complete tear down will be a must or 8f I can get away with the rod bearing replacement set I will send a link for the repair kit I'm thinking I may need
Old May 21, 2021
BrotatoChip's Avatar
Super Moderator
When a rod starts knocking it is dumping metal shavings into the oil which is then passed throughout the engine. It should really be completely torn down and cleaned to get the shavings out. It may be different since you own an Si but on the Civics I've had with rod knocks it's cheaper to just get another used engine (or at least the block and swap the head over once properly cleaned). Non-Si's are everywhere though so spare engines are cheaper. I've never actually tried to repair a rod knock.
At a minimum the crank and rod should be removed and checked at a machine shop. Otherwise your repair will not last long.
Old Jun 8, 2021
I've diagnosed the noise and I'm almost certain it's a main rod bearing that has gone bad. I have found some kids on eBay and other sites that are exclusively for replacing those bearings. Could you tell me a complete list of the tools I will need, and most importantly the size of the bolts holding the bearings in the rods? Also should I replace the bearings with stock OEM bearings or after market high performance bearings.
Old Jun 9, 2021
Super Moderator
To do a complete tear down? A lot of them. You sure you have the skills to do this?
I believe the rod bolts on this engine use the reverse Torx, size would be E14.
I will always recommend OEM internals for OEM designed use.
Old Jun 10, 2021
I have ordered what seals and parts necessary for this job I have all the tools I should need are there any tips techniques or any thing that I should know about that probably has not been covered in the multiple videos I've watched will the motor need to be jacked up loose from the motor mounts will any of the subframe need to be taken off etc stuff like that.
The parts should arrive on the 15th I attend on going to work on the very next morning once I have everything laid out in front of me wish me luck I'll take a video and let y'all know how it goes
Old Jun 10, 2021
FRSam's Avatar
Click Here
Just so you know, there's a very low chance that this fixes it, so don't be surprised if it doesn't.
Old Jun 11, 2021
Super Moderator
Just going to put these here.
You may very well have the skills to repair this but I would be amazed if this repair works. Especially if you're able to drive to work the next day. Bearings are not universal size (at least not OEM parts).
Old Jun 11, 2021
QUOTEcan I not use the codes on the engine block to find the right color of bearings
Old Jun 11, 2021
Super Moderator
Those codes on the block are for the crankshaft main bearings. For the connecting rod bearings there is a code on each rod and another on the crank next to each rod journal.
Old Jun 11, 2021
So I want know until I get in there? There is no way of knowing which bearings I will need before I start the year down.
Old Jun 14, 2021
Super Moderator
Correct. The only way to buy the proper sized OEM bearings is to open up the engine.
Old Jun 14, 2021
Not an 8th gen si, but here's how I saw the bearing colors for the D17A2 I took apart. Luckily I didn't have to change out bearings, but I still plastigauged it to make sure clearances were in spec.
Challa
General 10th Gen
Mar 3, 2021 11:59 PM
CraigW
Mar 19, 2017 12:09 PM
hwali78
Apr 16, 2014 07:17 PM
SiR_Tuner
Mar 28, 2006 06:56 AM
CivicRiderCA
Jan 9, 2003 01:43 PM
