HIDs and Retrofitting Discuss HIDs bulbs, ballasts, projectors and custom retrofits here.
HiR bulbs for 2010 honda civic dx-g coupe
Old Dec 28, 2020
Spitfire1944's Avatar
Spitfire1944 is an unknown quantity at this point
Hey guys looking for better headlight quality as I live up in Northern Ontario. Any idea where I can get these HiR bulbs I'm hearing so much about?
Cheers
Greg
Old Dec 28, 2020
Re: HiR bulbs for 2010 honda civic dx-g coupe
Edit - thought it was a typo of HID - ignore my reply below
you will need to open up your headlight by heating in an oven
you will need projectors that are designed to work on the HID's also.
https://www.theretrofitsource.com/bi...D2S?quantity=1
note that link above is for bi-xenon, where there is single bulb for high/low beams. if separate bulbs for high and low beams, need different setup
also, read stickies. you get more for the buck if you search and read before asking
https://www.civicforums.com/forums/2...1-install.html
wiring is less of an hassle nowadays, they are off-the shelf.
Old Dec 28, 2020
HiR (halogen infrared reflecting) @sdaidoji , not HID
Amazon would probably be your best bet. You'll have to slightly modify the tabs to get them to fit. 9011 if you want them in your high beam, 9012 for your low beam
Old Dec 28, 2020
oh, my bad...
wasn't familiar with the HIR at all... thought it was a typo...
OK, so found these:
https://store.candlepower.com/9011hir.html
https://www.hidplanet.com/forums/for...e-halogen-bulb
living and learning. Sorry, OP
Old Dec 28, 2020
they're basically beefed up, brighter halogen bulbs. I guess an infrared coating lets them produce more light and less heat
Old Dec 28, 2020
so then I still have to modify these to make them fit yes?
Old Dec 28, 2020
also I'm having a hard time finding the exact ones i need from amazon...any help would be appreciated.
Old Dec 28, 2020
https://www.8thcivic.com/threads/bul...t-guide.10184/
Depend on which you are going to change, low or high beams
Quoting from link:
"Low beam headlamp
9006
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen Upgrade: Up to 20% Brighter
9006CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005CB Cool Blue Halogen Upgrade: White Hot; Super Cool; 100% Street Legal"
Old Dec 28, 2020
Quoting from link:
"Low beam headlamp
9006
High beam headlamp
9005
Ok but isn't the 9011 and 9012 bulbs brighter then the 9005 and 9006 bulbs...hence the upgrade?
Old Dec 29, 2020
ah, i was under the impression that you wanted to know which is the low and high beams, but i see it was explained by Josh already. my bad
Old Dec 29, 2020
Thats ok...I'm just trying to get alot better light out of my headlights. But I also noticed that my headlight housings are pretty fogged up. So I'm probably gonna have to replace those aswell. But for now looking for the brightest headlight bulb I can find and the brightest yellow highbeam bulb for fog and winter weather up here. Because I can't put SI coupe fogs in this car because there is no wiring for them. So ill have to use yellow high beams for now.
Andy2016
Nov 4, 2018 04:58 PM
Nice not Rice
Lighting
Dec 24, 2010 12:25 PM
Revmaster
Lighting
Oct 18, 2004 11:28 AM
ImportRacer2123
Sep 10, 2003 10:24 PM
aZnVoYCe
Nov 15, 2001 04:48 PM
