Gabriel Ultra front struts and sway bar link
Old Apr 23, 2020
Andym's Avatar
Andym is an unknown quantity at this point
Hi,
I change my whole suspension parts a year ago exactly, struts were moonroe, they are badly shot bad quality compare to stock ones that lasted over 120k miles and didn't gave the problems these are giving. I just purchased Gabriel ultra from rockauto.c probably another garbage but I need it. Do I need to change any other parts again beside struts? Sway bar link or else together? I need new tires and alignment after. Ty so much
Old Apr 23, 2020
GolNat's Avatar
Prelude Owner
Re: Gabriel Ultra front struts and sway bar link
Maybe the endlinks I'd check them out. Also check your ball joints, tie rod ends and LCA bushings.
Old Apr 24, 2020
gabriel not a performance modification - moving to correct section of forums
Old Apr 29, 2020
Andym's Avatar
Exactly just replacing the struts noticed a tie rod completely loose on the passenger side and even the ball joint boot is cracked. I replaced all that a year ago and they didn't last it seems. Not as good as the ones that originally came with car. My front tires were like half way so wasted, I believe because of the strut I hope. I had been ordering parts from rockauto.com is there a better quality parts place you could recommend. Nothing seems to last too much
Old Apr 30, 2020
BrotatoChip's Avatar
Super Moderator
The one thing I like about RockAuto is it shows different quality parts. Did you buy the real cheap "Economy" replacements? Moog is a good brand, I've used them for ball joints, tie rod ends, and sway bar links without any issue.
Old Apr 30, 2020
Colin42's Avatar
Beck Arnley is also good
Old Apr 30, 2020
Andym's Avatar
Awesome, thanks a lot you people
Going for those
Old Apr 30, 2020
Andym's Avatar
Finished installing struts and now one wheel is bent inward and the steering feels loose and turning side ways byitself. I did put too much torque into the tie rod, since it was bad I thought putting some pressure was going to tighten a little more. Could that be the problem? And I have another concern about the strut mount and bearings, when I tightened the center nut, the bearings felt hard to rotate so I loosen it up slightly. Is this the way it's supposed to go? I didn't know the center nut rotated with the strut? What about the friction it does?
Old Apr 30, 2020
Any time you separate the tie rod from the strut, you should be getting an alignment
as far as mounting nuts, torque to spec, call it a day
Old Apr 30, 2020
Andym's Avatar
Then does it mean struts are not made equally even? The thing is way off toward inside like an inch. I got appointment may 6 for new tires and I wanted to make sure everything was rdy to go after to alignment . What a mess I'm in
Old Apr 30, 2020
Colin42's Avatar
Post pictures with the wheel on and off
Old Apr 30, 2020
Andym's Avatar
i just had put wheel back on, didn't had phone on me and I live in a place where I can't do mechanics. Has been stressing working like that.
Passenger side
Driver side
Old Apr 30, 2020
GolNat's Avatar
Prelude Owner
Center nut on the strut should be seated all the way down and tight (about 32-36 lb/ft if I had to guess). The bearing should rotate pretty easily and should move nice and smooth.
Did you mark the location of your old tie rods when you removed them? If the new ones are far off then it could make one wheel have more toe then the other.
Old Apr 30, 2020
Andym's Avatar
Old Apr 30, 2020
Andym's Avatar
Thanks, no I never touched or rotated the tie rods. They were same way as I took them out of the strut position
Old May 1, 2020
Super Moderator
So you just popped them out of the strut and then reinstalled after replacing? Didn't replace the tie rod ends at all.
It's possible the old struts were bent but an alignment fixed it. It's also possible the new one is bent, an alignment should fix it though. For the time being you can adjust the tie rods yourself to get it at least somewhere close. Definitely need an alignment before new tires.
Old May 1, 2020
Andym's Avatar
Wow, you got it right I think. A year ago I had hit one of those road sidewalk right up front on driver side wheel and the steering slightly twisted to the right. I was passing by a bad time and so I took it to a alignment shop. Now that you say I always had the worry is anything got bent or not. So this might be the concequences now. How do I fix it now to be able to move the car?, besides the Tie Rod adjustment are there other screw to play with the alignment part. I have no clue what they do to it at alignment shop but I'm going down under today in a while to see what to do.
Old May 1, 2020
GolNat's Avatar
Prelude Owner
On a 7th gen I don’t think you can adjust much except toe which is done with the tie rods.
Old May 1, 2020
Andym's Avatar
Appreciate very much you people time, and knowledge given to help on this. Thanks so much.
i was able to adjust and appeared quite simple not complicated as I was worrying about.
Passenger side tie rod is in terrible condition. Trying to order now the few parts around there.
Moog or beckarnley. Also wondering about PROFORGED brand proclaimed as a premium part, wonder if is as good or better cause prices are quite low
Old May 1, 2020
Super Moderator
I have no experience with PROFORGED but based on price being slightly higher than MOOG and the fact Amazon says it comes with a 1,000,000 mile warranty I'd say they're quality parts.
Definitely get a professional alignment after replacing tie rods and before new tires (or very soon after).
mrohitredd
Jun 9, 2015 06:37 AM
spangle6
Dec 12, 2012 01:10 AM
baiwldrnner
Nov 7, 2007 01:59 PM
MangoEX
Aug 20, 2003 02:35 PM
2k1Miami
Mar 5, 2002 02:52 PM
