'94 VX won't start. Dink-Donk noise
Old Mar 10, 2020
alaskanaking's Avatar
alaskanaking is an unknown quantity at this point
When I turn the key in the ignition, all that happens is a fairly loud dink donk noise that sounds like it is coming from the dash behind the steering column, or maybe on the other side of the firewall. The noise just happens once. If I turn the key off and back on, I again hear a single dink donk. The engine doesn't turn over. The car ran fine when I turned it off the day before, but it has been intermittently cutting out, once in a while, the past few weeks. That may not be related. Also, my battery is 12 years old (I know, crazy) but has been fine. I bought the car new in 1994. It refuses to die. Anyone recognize this sound? Thanks from Alaska!
Old Mar 11, 2020
mac25's Avatar
Dr Krieger of Modification
Re: '94 VX won't start. Dink-Donk noise
-make sure battery connections are tight
-make sure grounds are free of corrosion
-cheack related fuses and relays
-try jumping the car
does the starter activate? Does the car start?
do the steps above, if everything works enjoy; if there are more issues report back.
ps: audio clip would be easier to understand.
Old Mar 11, 2020
Jump starting didn't do anything. Starter doesn't activate. All I get are these clicks. Each time I turn the key on I get two clicks. Here is an audio file. I turned the key on about 13 times in this audio clip. Hope it loads OK, I'm not good at audio files, etc. Thanks.
File Type: mp3
Old Mar 13, 2020
mac25's Avatar
If you're not hearing the starter than either the starter is dead or there is no power to it.
In this case I'd suspect a fuse or relay. How's the main fuse?
If it's not the main fuse you will need to check all related components in the starter circuit.
-the circuit diagram can be found in a Haynes manual if you cant find it online.
Old Mar 15, 2020
All fuses OK.
Old May 28, 2020
I solved the problem. It needed a new battery!!!! I didn't think that was the problem because trying to start the car with one of those battery-pack jumpers did not work. I had used that jumper battery on a Highlander a week earlier and it worked fine, and it was fully charged. So I assumed a weak battery was not causing the problem. I was wrong.
PiinkSox
Jul 25, 2006 07:10 PM
Natedowg
Apr 23, 2006 07:29 PM
Michalo187
Feb 6, 2006 08:33 PM
paul2003ca
Feb 20, 2005 10:26 PM
CivicRookie
Dec 18, 2002 08:48 PM
