lowering cars
Old May 25, 2002
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
lowering cars
Okay im just wondering how low is low w/o needing camber kits and damaging your axles? i work at an auto shop and i thought 1.5 was the lowest you can go w/o camber and damaging your axles... but now ive heard different answers... err... our ph-uckin civics is too high.. probably 3 inches too high lol.. i wanna know how low can i go...
Old May 25, 2002
silver2k2civic's Avatar
silver2k2civic is an unknown quantity at this point
I'd like to know to. I don't have a qlue[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 25, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Because of the suspension geometry in our cars, anything lower than 1" will require a camber-correction kit...you may not see it but your tires will wear uneven and/or faster.
Old May 25, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
i lowered mine 2 inches with no camber kit. the camber is off 1 or 2 degrees but my tires havn't been affected yet(20,000 miles) and you wont damage your axles but your wheels bearings do take a beating if you get low profile tires.
Old May 25, 2002
18inchpride's Avatar
18inchpride is an unknown quantity at this point
I just finished reading last months import tuner and it was all about the facts and fiction of lowing your car!! if you lower your car then you really need to get a chamber kit because it can f*ck up you alighnment big time!! there are so many things that you have to take into consideration when lowering your car and making sure that you have every nook and cranny will save you in the long run!
JONNY
Old May 25, 2002
Sekz God
SO what would u need if you lower ur car around 1.5 in? or maybe 2?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 25, 2002
civicpimpin01's Avatar
civicpimpin01 is an unknown quantity at this point
I would just save up for everything, the shocks, the springs or coilovers, the camber kit,etc.
Old May 25, 2002
LJ's Avatar
LJ
Fernando The Donkey Lover
LJ is an unknown quantity at this point
the place where I got my car lowered said that I wouldn't need a front camber kit because of our suspension int he front, so ya, i didn't have one with the gold line springs, and my alignment and camber was fine
Old May 25, 2002
Vatch's Avatar
Vatch is an unknown quantity at this point
The front the ajustment is easy... just need camber bolts ( like $50)... but In the back it's a different thing.
Old May 25, 2002
RedDragon333's Avatar
Im with CivicPimp on this one i would rather be on the safe side of everything and save up for the camber kit, springs, shocks and struts and the alignment...its costly but itll save you in the long run if your gonna do it do it right the first time leav e no room for a second
Old May 25, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
How much does a camber kit usually go for? You have to buy one for front and then rear...so how much should i expect to pay? I'm just wondering. I'm only dropping my car 1" all around though.
Cheers,
the BALLER
Also...should i invest in koni's?
mistermenphis22
Apr 3, 2016 08:06 AM
bsmiley
Apr 27, 2015 01:27 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
ImmortalEX
Oct 31, 2001 10:00 PM
