lowering cars
Sekz God
lowering cars
Okay im just wondering how low is low w/o needing camber kits and damaging your axles? i work at an auto shop and i thought 1.5 was the lowest you can go w/o camber and damaging your axles... but now ive heard different answers... err... our ph-uckin civics is too high.. probably 3 inches too high lol.. i wanna know how low can i go...
i lowered mine 2 inches with no camber kit. the camber is off 1 or 2 degrees but my tires havn't been affected yet(20,000 miles) and you wont damage your axles but your wheels bearings do take a beating if you get low profile tires.
I just finished reading last months import tuner and it was all about the facts and fiction of lowing your car!! if you lower your car then you really need to get a chamber kit because it can f*ck up you alighnment big time!! there are so many things that you have to take into consideration when lowering your car and making sure that you have every nook and cranny will save you in the long run!
JONNY
JONNY
Fernando The Donkey Lover
the place where I got my car lowered said that I wouldn't need a front camber kit because of our suspension int he front, so ya, i didn't have one with the gold line springs, and my alignment and camber was fine
Im with CivicPimp on this one i would rather be on the safe side of everything and save up for the camber kit, springs, shocks and struts and the alignment...its costly but itll save you in the long run if your gonna do it do it right the first time leav e no room for a second
How much does a camber kit usually go for? You have to buy one for front and then rear...so how much should i expect to pay? I'm just wondering. I'm only dropping my car 1" all around though.
Cheers,
the BALLER
Also...should i invest in koni's?
Cheers,
the BALLER
mistermenphis22
Apr 3, 2016 08:06 AM
