97 civic won't go in any gears
Old Jul 4, 2019
Reedtech's Avatar
Stoned Mechanic
Reedtech is an unknown quantity at this point
I just baught a 97 civic that runs well but won't shift. Prior owner said he put a new clutch in and there were no transmission problems since. D16y8 motor 2dr coupe 5speed. I'm thinking the master or the slave cylinder. I bled the clutch, no change. Rubber boot around slave is cracked and has fluid in it.
Old Jul 4, 2019
Colin42's Avatar
Re: 97 civic won't go in any gears
Are you sure the clutch is disengaging when you press on the pedal?
Old Jul 4, 2019
Reedtech's Avatar
Stoned Mechanic
Doesn't seem to be it starts fine without holding the clutch.
Old Jul 4, 2019
Colin42's Avatar
Could try the slave first since it's pretty cheap. When you bled the clutch were you pumping the pedal? Did it feel normal?
Old Jul 4, 2019
Wankenstein's Avatar
Check the CV axles to see if they popped out from the transmission differential.
Old Jul 4, 2019
Reedtech's Avatar
Stoned Mechanic
Yes friend pumped it felt normal too. I got a slave and master I'll install tomorrow.
I'll check but the prior owner said they were new.
Old Jul 4, 2019
Only one of the CV axles power the car. Pretty sure it's the passenger side. Probably best to install slave cylinder only first and see if that solves it. The master cylinder can be a bit difficult to install and will tend to leak first (inside cabin top of clutch pedal) before giving out.
Old Jul 5, 2019
Reedtech's Avatar
Stoned Mechanic
No leaks from master. Replaced slave and bled system no change. Have a new master on hand will replace shortly.
Old Jul 16, 2019
Reedtech's Avatar
Stoned Mechanic
Towed it to Aamco they wanted 1600 to replace clutch, master and slave. Slave is brand new too. I towed it back replaced the master and still no change. I looked under the clutch pedal and found out its been safety bypassed which explains why it starts with no clutch pedal. I bled the system with a friend. I don't currently have anyway to know if it has air in the line without clear hose but the pedal feels firm and the system feels pressurized. I want to bleed it better to see if that changes anything. I am disappointed I haven't figured it out. I guess I'll be doing the clutch by myself with a friend. Just hoped it didn't have to come down to that. Any ideas?
Old Jul 18, 2019
Pointing to the issue is internal. Ezone and Slumpert are Honda mechanics and can most likely help you.
Old Jul 23, 2019
Reedtech's Avatar
Stoned Mechanic
I started working on taking stuff out to drop the transmission. Took an hour of whacking the pin in the shift linkage to get it out. Tomorrow I'll finish taking off the mounts and drop it.
Interstingly after I removed the starter I looked inside the whole and wiped the clutch pressure plate with a finger and it was coated in oil. The bolts holding the starter in were covered in oil too. I think maybe the rear main seal busted which is why theres a lot of oil. I only purchased a stage 1 clutch kit which comes with clutch, plate, pilot bearing and throwout bearing and alignment tool. So I may need to buy a rear main seal now too. We'll see tomorrow.
Old Jul 26, 2019
Reedtech's Avatar
Stoned Mechanic
Fixed!
Restored the lenses with turtle wax 3n1 kit 10 bucks for brand new lenses! Took 15 minutes.
She bright now!
I replaced the clutch, pressure plate, throw out bearing, master and slave cylinders. I learned everything about my Civic in a week. I could have saved a lot of time and money if I knew what I know now.
THE CV AXLES WEREN'T IN ALL THE WAY WHEN I GOT THE CAR!
https://youtu.be/Uz2s_rS4M0c
That being said I have no way of knowing if that was the exact cause of my original problem but I have a good idea it was and here's why. When I was finished and added transmission fluid in I noticed it poured out of the diff seals where the cv shaft goes in. I took the wheel hun off and ball joint and tie rod and grabed the shaft of the cv where it goes in the hub with one hand holding it in place while using my other hand on the main shaft pulling back slightly and pushing forward with force to but the cv boot into the diff seal. I reassembled everything started it up after checking fluids and put it in reverse and slowly released the clutch. It worked like a brand new car. Now I have to break the clutch in over 500 miles driving like grandma. I test drove it and it runs and drives good. Pulled her in the garage and noticed oil all under the distributor. And orange rtv and oil all over the vtec solenoid. I replaced both gaskets and removed all the old rtv. Leak gone, car runs great now! Ty everyone and save time and money, if your clutch doesn't work, make Sure the cv axles are in the diff all the way.
First look at car before buying it.
Trying to keep things clean. Everything was black when I got it.
Brand new clutch came out, went ahead and replaced it all. This was a seco oem clutch I'll save it for next time.
New Clutch in.
She works!
Just backed it out after reassembling the body.
Old Jul 29, 2019
Colin42's Avatar
Glad you got it going dude
Old Jul 29, 2019
"I could have saved a lot of time and money if I knew what I know now.
THE CV AXLES WEREN'T IN ALL THE WAY WHEN I GOT THE CAR!"
Refer to reply #5
Quinc
Jun 27, 2017 05:03 PM
Mkalby
Nov 30, 2012 03:31 PM
peachrules
Jan 10, 2012 09:58 AM
maxof777
Jul 2, 2010 10:13 PM
chopper202
Oct 6, 2009 03:30 PM
