General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
91 Honda Civic Hatchback Si 1.6L with 500k
Old Sep 27, 2018
civicenter's Avatar
civicenter is an unknown quantity at this point
Thinking about getting a new engine for my 91 Honda Civic Hatchback Si.
What are my options? B16 engine swap or try to get a used and original D16A6 engine on it?
I thought about removing the head to get it rebuilt but I'm not too sure that the bottom end is going to be holding up very long.
Car still runs and does not overheat but I am loosing engine coolant.
Anyone know of a good shop out here in California that can rebuild heads or a shop that sells and installs B16 engines?
Is the B16 swap just a simple swap or are modifications expected?
Any advice is greatly appreciated
Old Sep 29, 2018
Re: 91 Honda Civic Hatchback Si 1.6L with 500k
There's a lot of places coolant can be lost, sometimes without a lot of obvious evidence.
Better track down the true cause before you assume a head gasket or engine would fix it.
Gonna suck if you drop a load on an engine then find out it was a seeping heater valve that only cost $15, LOL
Old Jan 14, 2019
civicenter's Avatar
How would I know or how would I check to see if I have a bad heater valve?
Are there any symptoms from my heater or AC that would indicate a bad heater valve?
kingfisher
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 25, 2019 08:25 AM
prr
Sep 29, 2018 02:44 PM
jerineer
Mar 12, 2016 04:28 AM
cskaggs19
May 2, 2011 11:20 PM
pokerstarcole
20
May 6, 2007 08:27 PM
