2003 civic repaired won't rev past 2k rpm
Old Jan 19, 2018
PB2003's Avatar
PB2003 is an unknown quantity at this point
Hi everyone hoping some one can give me an idea here of how to solve my issue .
we replaced the clutch and while doing so battery was unhooked and charged .
everything is back together now and the car starts and idles immediately .
put my foot on the clutch put in first rev to go forward it won't rev past 2500 and I here a clicking noise sounding like
its from the glovebox area and its like an engine cutout ignition .
the car won't move and will stall if I keep letting the clutch out as the revs aren't there to move it .
any ideas ? I'm thinking ground all checked ..
loose alternator
battery terminals
I'm lost
Thanks Pete
Old Jan 20, 2018
Re: 2003 civic repaired won't rev past 2k rpm
These symptoms always come up after someone forgets to tighten all of the alternator mounting bolts, and bad grounds can make the same things happen.
Lost grounds or forgotten/loose ground cable for the trans case?
Ground at the upper water neck? small grounds right next to that cable?
Loose alternator bolts?
Fix it before it destroys the PCM...that's not cheap.
Old Jan 20, 2018
PB2003's Avatar
Thankyou only ran it for a minute -I'll recheck all the grounds and post my findings
Old Jan 20, 2018
PB2003's Avatar
Well just as suspected it was a few grounds one on alternator the other was on stat housing .
my son installed the clutch in shop class and missed a few bolts being tightened .
i diagnosed it by accident when I pushed down on air box the car turned off .
lifted the box off found loose bolts / nuts and started it that also cleared the code the scanner read .
drove today for a few hours and purrs like kitten ,
thanks for for the ideas
Pete
Old Jan 21, 2018
Pete
Good to hear it
What code(s) did the scanner read?
This shop class would seem to be missing something critical to successful repair, business, and career.
Old Jan 21, 2018
PB2003's Avatar
Yes - my son didn't believe me .I also assumed the teacher would go over everything .
after that I asked did he check and tourq each of the bolts on clutch install and for everything else .
i then said great job son that's ok your learning and there is a lot to put back together .
code P1106 which relates to ecu .
Tyler1994
Mar 18, 2016 10:21 PM
Tpowell
Nov 4, 2014 07:20 PM
Dustin19902
Aug 10, 2014 08:00 PM
Blkcivic787
Mar 30, 2014 02:45 PM
hoppy
Aug 31, 2012 03:28 PM
