2002 LX heater issues.
Old Jan 6, 2018
Gmwirth's Avatar
Gmwirth is an unknown quantity at this point
Greetings all. I am new to Hondas, but really like my recent purchase of a black '02 Civic LX. It has a completely rebuilt engine due to a blown head gasket and a warped head. Everything has been running great till the other night on my way home from work when the heater started blowing cold air. The thermostat never budged from normal, engine still purred like a kitten. When I got home, I checked the coolant in the radiator and in the reservoir/overflow and it was all good. No wet passenger floorboard. With other cars I've owned, I've had a similar problems and had to replace blend door actuators. Is this someone that these civics have? Or does anyone have any other suggestions? I have seen many other threads with heater or a/c issues but none the same as this, although I may need one of the same fixes. If anyone has any suggestions they would be greatly appreciated! Thank you!
Old Jan 7, 2018
Wankenstein's Avatar
Re: 2002 LX heater issues.
Originally Posted by Gmwirth
on my way home from work when the heater started blowing cold air. When I got home, I checked the coolant in the radiator and in the reservoir/overflow and it was all good.
Check both levels again when the engine is cold and do so each day for a week.
May end up being the issue. Can you hear the servo motor when you select climate control from max cold to max heat (or vice-versa)?
Check the heater inlet valve (engine bay/firewall) to see if it moves when you adjust climate control from max cold to max heat. Also check all linkage from under dash that connects to the heater inlet valve.
The following link may be related: https://www.civicforums.com/forums/3...r-low-rpm.html
You might want to try bleeding air from coolant system (per service manual).
Old Jan 7, 2018
Gmwirth's Avatar
Thank you for the great information. I will burp the system today. As for the blend door, there is a definite change when switching between cold and hot, and I don't here clicking or anything when it is switched from cold to hot or vice versa, which is why I didn't immediately jump to that conclusion, just questioned it. It was just odd to me because I was driving down the road with the heater on and it just instantly started blowing cold. I will update later today after I burp the system. Thank you again guys for your input, it is much appreciated!
Old Jan 7, 2018
Old Jan 22, 2018
Gmwirth's Avatar
Greetings! Please forgive me for not updating before now. Life and some other issues with the car prevented me from getting back to this thread and this issue. I had the dreaded crank but no start issue. Turns out it was bad plugs. That issue now resolved, I am back to the no heat issue. After burping the coolant system twice, I still have no heat. The heater inlet valve does move when switching from hot to cold or vice versa, The two hoses going to and from the heater core are not hot, nor do they feel like there is anything running through them. The coolant level in the radiator does go up and down when you squeeze those two hoses. I am at a loss as to what the next step would be. I would really to have some heat as it is pretty cold in the mornings here in Southeastern Colorado. Any help would be much appreciated! Thanks!!
Old Jan 22, 2018
Slumpertcivic's Avatar
Would not surprise me if the previous owner put something like stop leak in when he was having overheating issues and that stuff finally clogged up your heater core.
We are still not sure those lines aren’t just full of air though, might consider disconnecting one and seeing if you can add coolant right in.. if it’s clearly full of coolant then I would disconnect the other heater hose and test for blockage.
It only takes minutes to remove airbox and intake resonator giving you lots room to get to the hoses
Old Jan 22, 2018
Thermostat good? Top radiator hose gets screaming hot? Temp gauge stands in the middle when warmed up?
Ya, you could disconnect hoses between engine and heater system and use a garden hose to check flow and try to purge out any debris, and
.......inspect operation of that water valve, maybe it broke internally and doesn't actually open and close the passage now even though the lever still gets moved. (manual flow test with the garden hose, or something)
Old Jan 26, 2018
Gmwirth's Avatar
Red face Re: 2002 LX heater issues.
Thank you for the information and the next things to try. I will get to those this weekend. Right now I am having a repeat of the dreaded crank and no start problem. This is very frustrating as I thought I had the problem solved with new plugs. Im searching all the crank no start threads and gonna spend the weekend working on my Honda. I hope that I can get all these issues resolved as I really like this little car and its perfect for my daily commute which is about 100mi round trip.
Tbolan91
Jan 25, 2017 07:55 PM
Kevin_646
Mar 1, 2014 10:48 PM
lawman2391
Dec 8, 2013 02:11 PM
Civicnoobie
15
Nov 13, 2012 03:45 PM
webster426
Air Conditioning
28
Jan 7, 2012 12:27 AM
