Mysterious Overheating honda
Old Aug 15, 2016
Mechkat's Avatar
Mechkat is an unknown quantity at this point
Hi, I've got a Honda Civic lx that won't stop overheating at high speeds with the AC on. I've recently replaced the radiator, rad cap, rad hoses, and the thermostat. Both fans are working fine and I can't figure out what else it may be. I've considered the head gasket, but I heard that if that were the problem I should have white exhaust and milky oil. The car does fine on low speed roads, but as soon as I hit about 65mph it shoots to hot. I then proceed to turn on the heat and slow down which normally works to get home but it's a constant game the entire way, and I can't seem to figure out the source of this problem. Could use any help, thanks!
Old Aug 15, 2016
Colin42's Avatar
Re: Mysterious Overheating honda
its the head gasket
go read this:
https://www.civicforums.com/forums/3...reference.html
do the pressure test described in the thread with shop air it will prove that its the head gasket
Old Aug 16, 2016
Wankenstein's Avatar
Head gasket or partially failed waterpump. Pray it's the waterpump.
t.ralsty
Jul 2, 2016 10:24 PM
BrianDye
Oct 31, 2015 10:59 AM
trv020
Oct 28, 2015 10:37 PM
johnmcm7
Oct 27, 2015 09:30 PM
shriketheavatar
Oct 20, 2015 08:31 PM
