Adjuster Bolt snapped
The adjuster bolt (power steering pump bracket) for the power steering belt snapped when we were trying to tighten it.
Is the car still drivable (safely)?
I cannot seem to find the part number ... the bolt is #9 in the diagram.
Re: Adjuster Bolt snapped
Remove loose pieces.
Safe enough to drive, if you still have the belt tight enough for the power steering to work.
I'd just replace with a long regular bolt, no real need for a wing on it.
2002 Civic wing bolt for power steering adjustment
# 56996-P01-000
# 56996-P01-000
I'd just get the belt tight using a pry bar or whatever then lock it down.
I don't NEED the adjuster bolt to get the belt tight.
I never use the one under the alternator when doing belts, I snug it after I'm done just to make sure it can't fall out.
rb26dett26
Jan 28, 2016 07:30 AM
MG-70
Lighting DIY
Nov 17, 2015 07:18 AM
