Headlight/ignigtion buzzer not working
Old Oct 6, 2015
pcusack's Avatar
pcusack is an unknown quantity at this point
Exclamation Headlight/ignigtion buzzer not working
I have an 01 civic coupe and none of the buzzers work.
I have seen other similar threads but my car is different. The dome light doesn't work on "door" setting, with pass or driver door
Headlight/ignition buzzers never turn on, but dome light will turn on when switched to "on" setting.
Ive checked every fuse, and also the door jam sensors (youtube vid shows they fall out) mine are still in on both doors.
link to vid:
The "door ajar" light doesn't come up on dash when either door is open.
If someone could offer insight that would be awesome. It's a very annoying issue bc my battery died twice.
Thanks!
Old Oct 6, 2015
Re: Headlight/ignigtion buzzer not working
Power locks don't work either?
AC inoperative too?
Red brake light on the dash all the time?
Old Oct 7, 2015
pcusack's Avatar
AC inoperative too?
AC will blow air, but not cold. Brake light has been on dash the entire time the problems have been around (forgot to mention)
Also, power locks stopped working
Is this the mcu?? (or whatever it is called)
Old Oct 7, 2015
CraigW's Avatar
Being an 01, there is a good chance it is.
Those are all classic symptoms.
Old Oct 7, 2015
pcusack's Avatar
First I've heard of the 01's mcu issues, i have heard 00-01 accords and civics all have bad (automatic) trannys. Any truth to this?
if so, i definitely will stay away from those years/models
Old Oct 7, 2015
More than just 01.
Search for the terms MICU or Multiplex instead of mcu.
Old Oct 7, 2015
CraigW's Avatar
This board used to be 7th gen exclusive... they are on here.
miatabro
Jul 17, 2015 12:12 PM
Nalmonte
Jun 3, 2015 11:01 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Thees1
Apr 14, 2015 08:23 AM
Killagi
Apr 12, 2015 10:42 AM
