1st 3rd and 5th gear. Need ANSWERS!
Old Sep 24, 2015
ThatGuy913's Avatar
ThatGuy913 is an unknown quantity at this point
So im having this issue with my car, but trying to get some ideas what's causing it. People have told me it's my fly wheel or my bushing for my shifter, shifter cable etc..
1st 3rd and 5th gear can slide up which it isn't supposed to. I ask one of my buddies mechanic and he's telling me that it's my bushings on my shifter. 2nd, 4th and reverse goes in nicely. When I shift it's goes in soft and weak. I swapped my motor to a D17A not to long ago and was thinking that he didn't rotate my fly wheel. Im clueless at the moment. Anything that you guys know or well fix this problem, well be totally appreciated!.. Forgot to mentioned that when he swapped my motor out. I needed a new clutch, so he installed that since it was easier to do when the motor is being replaced/.
Old Sep 24, 2015
Re: 1st 3rd and 5th gear. Need ANSWERS!
Post your car info please.
Explain more?
Old Sep 25, 2015
ThatGuy913's Avatar
Explain more?
The gears would go in, but I'll have to slowly push it into 1 3 and 5th. If I stomp on the gas pedal and try to shift it into the 3 gears it won't go into t
Old Sep 25, 2015
Year, model, trim?
Old Sep 25, 2015
ThatGuy913's Avatar
Year, model, trim?
2005 Civic ex with a D17a motor
Old Sep 26, 2015
2005 Civic ex
Well that eliminates at least one TSB.
See if the shifter linkage at the trans has come loose or a housing retainer clip is missing. Have someone work the shifter while carefully observing cable and linkage movements.
Old Sep 28, 2015
ThatGuy913's Avatar
Idk what the dude did, but all he said was your clutch is going to be out soon, so you might as well change your clutch. I said yeah and he changed it, but I drove it for almost a month and then that just randomly happened when I was starting my car up before leaving work.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Islesfan
Sep 29, 2015 03:42 AM
speedlever
Sep 24, 2015 07:18 PM
beanhead
Sep 24, 2015 12:04 PM
BBrosario
Sep 17, 2015 07:51 PM
