resetting trip meter in 01 civic ex button not responding
Old Jul 31, 2015
emich's Avatar
emich is an unknown quantity at this point
In the past few months I have noticed I have to press much harder to get a response. Is this repairable?
Thanks
Old Jul 31, 2015
GolNat's Avatar
Prelude Owner
Re: resetting trip meter in 01 civic ex button not responding
Mine is like that too. Try putting slight upward pressure while you push it, see if it helps.
You have to pull the gauge cluster out, not sure if it's repairable or not without replacing the whole assembly.
I just left mine on mileage and stopped touching it so it didn't get stuck. I didn't feel like taking it apart to fix it. My maintence light has been on for like a year.
Old Jul 31, 2015
emich's Avatar
I have tried pushing it in every direction without success.
If I can take out just the **** a pencil eraser and cleaning solution with cotton swab will do the job.
Old Jul 31, 2015
CraigW's Avatar
It is likely a tact switch on the circuit board.... and, more a mechanical then electrical issue.
Old Jul 31, 2015
emich's Avatar
It is both. The same type like TV remote.
Old Jul 31, 2015
Mine's been like that for ages. It sucks. I even took apart the cluster, cleaned to contacts, but nothing worked. I just use a blunt instrument (like my removable bit screwdiver, bit removed) put some pressure on the right side while pushing it in, and even then, it responds quite poorly. Resetting the maintenance light is not so fun, but it's doable.
Old Jul 31, 2015
LOL, same here
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Jonnie.
Jan 13, 2019 11:21 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
AnotherDopeStyle
Nov 1, 2001 01:58 PM
