A/C compressor bolt broke
Old Jul 29, 2015
tmarron0's Avatar
tmarron0 is an unknown quantity at this point
One of the bolts that hold the A/C compressor to the mount snapped off when I was loosening it. Has anybody had this problem and would it be fine if I just put it back on with only 3 bolts?
Old Jul 29, 2015
Re: A/C compressor bolt broke
I'd fix it.
Remove the bracket.
Drill out the broken bolt.
Repair/restore the threads if necessary and replace the bolt.
If you don't have the finesse to drill on center and save the bracket, take it to someone who can.
Old Jul 30, 2015
tmarron0's Avatar
I did try and drill it out but I was off just a little and if I tap it the hole will not line up and allow the bolt to go in. Do you think there would be a problem with just 3 bolts holding the compressor on?
Old Jul 30, 2015
emich's Avatar
emich is an unknown quantity at this point
Leave it with 3 bolts but check periodically if the bolts are holding
Old Jul 30, 2015
I guess it's up to you. Either try it and see what happens or buy another bracket?
cukaracha
30
Jul 26, 2015 12:01 PM
EliseKStewart
Jul 15, 2015 11:11 AM
muttleytm
Jul 14, 2015 05:31 PM
beeemerdude
Jul 10, 2015 09:22 PM
AaronSorenson
Jul 7, 2015 09:40 PM
