8th Gen 2006 - 2011.
2013 Center console disassembly
Old Jul 28, 2015
rman1900's Avatar
rman1900 is an unknown quantity at this point
I'm looking for any diagrams for 2013 Civic center console disassembly.
I found quite a bit of information for older models, but not for 9th gen.
It looks like:
Thanks in advance.
Old Jul 28, 2015
Re: 2013 Center console disassembly
Originally Posted by rman1900
It looks like:
Image failure?
Old Jul 28, 2015
rman1900's Avatar
oops - looks like i missed the images. one more try:
Old Jul 28, 2015
Stock photos? LOL
Pull handbrake up high
Plate and tray around shifter (auto trans), start at the rear edge and pry it up to release clips, then pull rearward. Don't yank out any wires. You may need to move the shift lever back.
Unplug the stuff attached to the tray.
ANother connector under the tray toward the front of it needs disconnected to pull the console out.
Cupholder should pull straight up, another bunch of clips holds it in.
Small square of carpet in the armrest storage compartment comes out.
Then you should be able to find all the bolts that hold the center console in....probably 2 inside the armrest storage compartment... another 3 or so around the shifter.
2 pushpins on the outside at the front edges have to come out too.
Old Jul 28, 2015
rman1900's Avatar
@ezone - many thanks. Any idea how to get off the shifter **** ?
Old Jul 28, 2015
Manual or automatic?
Old Jul 28, 2015
If manual trans, which engine do you have?
Old Jul 29, 2015
rman1900's Avatar
@ezone - it' an automatic - 1.8L
Old Jul 29, 2015
You don't need to remove that to get the center console out.
Old Jul 29, 2015
rman1900's Avatar
Many thanks. So I don't break anything :-) - want to clarify:
"Plate and tray around shifter" - is that the black PRNDD3... plate #1
or the grey mezzinine on the console #2 - picture below:
Thanks again.
Old Jul 29, 2015
#2. Pry upward at the parting line just below the line for #2 in your pic.
The PRNDL trim (#1) stays where it is, the gray trim (#2) lifts up around it.
The trim you labeled #2 in your pic is #17 in this parts diagram
Old Aug 1, 2015
rman1900's Avatar
@ezone - disassembled and re-assembled. Thank you very much for the information.
Old Aug 1, 2015
Right arm!
Old Aug 1, 2015
rman1900's Avatar
@ezone - :-)
To redeem myself for posting stock images, I'm posting my images with instructions.
It's a bit detailed - but hope can return the favor.
Thanks again Ezone.
Old Aug 1, 2015
rman1900's Avatar
Wonder if anyone tried installing a couple extra USB charging ports into the front bin area next to the Aux port. There never seem to be enough charging ports when wife is in the car.
Old Aug 1, 2015
Great write up
Guess I had most of it right but I didn't see the one screw in front tray in the instruction list nor taking the rear cover off the back of the console.
Old Aug 1, 2015
Check this out
https://www.civicforums.com/forums/3-general-automotive-discussion/340806-what-did-you-do-your-civic-today-73.html#post4689585
There are a few more pics posted after that, scroll on down the posts and see what they have done
Posts# 2185-2188 have pics
Old Aug 1, 2015
rman1900's Avatar
Very clever. I'm wondering if I can just drill a hole and permanently install something like this:
Amazon.com: SCOSCHE USBC242M 12 Watts per port (24W/4.8A total output) USB Car Charger - the FASTEST CHARGE RATE for Apple and Android Devices -  Retail Packaging - Black: Cell Phones & Accessories Amazon.com: SCOSCHE USBC242M 12 Watts per port (24W/4.8A total output) USB Car Charger - the FASTEST CHARGE RATE for Apple and Android Devices - Retail Packaging - Black: Cell Phones & Accessories
Old Aug 2, 2015
There's probably enough room to install a second power outlet, then you can just plug that in when needed
Or....
Google image search came up with this
This looks promising too, want to whittle a rectangular hole somewhere?
Old Aug 2, 2015
rman1900's Avatar
hmmm -
Old Sep 10, 2018
civic39227's Avatar
civic39227 is an unknown quantity at this point
@ezone - :-)
Thanks again Ezone.
can’t see any images
Old Sep 10, 2018
Colin42's Avatar
Thread is 3 years old...
Forum Bot
Interior DIY
Jun 6, 2011 08:37 PM
cwo715
Jun 29, 2006 02:04 AM
sictoy
Mar 21, 2004 01:42 PM
slicksivik
Jan 31, 2003 05:30 PM
Unomyname
Jan 19, 2002 09:02 PM
