Crankshaft position sensor
Old Jul 7, 2015
aultman1990's Avatar
aultman1990 is an unknown quantity at this point
So I finally got the crankshaft off to change the sensor under the lower timing belt cover but can't get the wire connector off to change it for the new.one . big hands little space under the top of engine any ideas
Old Jul 7, 2015
Re: Crankshaft position sensor
Oh yeah that one sucks and it's been a long time since I've had to get one apart.
Try to get the connector loose from its mounting tab so you have some room to get your fingers around it?
Take off the top bracket for the alternator and lean the alternator toward the rear as far as it will easily go? (I don't have a car to look at, so I can't tell if this would really help)
Old Jul 7, 2015
I will try its raining now so tomorrow
Old Jul 8, 2015
EdGasket's Avatar
EdGasket is an unknown quantity at this point
I don't think that sensor under the lower timing cover is the crankshaft sensor; it is something else and I understand the car will run without it.
Old Jul 8, 2015
The box and online calls it that
Old Jul 8, 2015
EdGasket's Avatar
Ah here:
http://honda-tech.com/tech-misc-15/c...n-help-833005/
Crankshaft Fluctuation Sensor. Not sure if it is what the engine uses to time the spark as with most normal crankshaft sensors; I thought that signal came from the distributor but maybe that is only on earlier engines?
Old Jul 8, 2015
I guess
Old Jul 8, 2015
EdGasket's Avatar
Here we go:
http://honda-tech.com/honda-civic-de...stion-2743403/
"The ECU uses the 3 sensors inside the distributor to coordinate fueling and timing efforts. The CKF sensor was introduced for OBD2 misfire detection and will not keep your car from starting."
Old Jul 8, 2015
I checked the distributor and alternator and spark plugs this was the last thing before I got to get someone to check electrical wires.
Old Jul 8, 2015
Right..... My info says the same.
What problem is the OP chasing here?
Old Jul 9, 2015
I got it changed still no start. And spark plugs have no spark
Old Jul 9, 2015
The camshaft does turn, right?
Pull distributor cap off, check for spark directly out of the ignition coil.
Make sure the rotor spins when the engine is cranked.
Use a grounded wire or grounded screwdriver to check for spark at the coil. Hold it up to the coil tower and have someone crank it for you. See how much spark you can get (how long of a spark you can get).
If you get lightning bolts coming out like over a half inch long it's good and your problem should be in the cap/rotor/wires.
If you can only get the tiniest spark to happen like only 1/16 inch long and no more, it's a bad coil.
If no spark at all then more checks are needed.
HTH
BootyDo
Jun 21, 2016 03:45 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
ZILLA
Jul 10, 2015 06:05 AM
CivicsClass101
Jul 9, 2015 11:14 AM
