Parasitic drain through Fuse 9 "backup" 2001 Civic EX
Old May 25, 2015
wankers's Avatar
wankers is an unknown quantity at this point
Question Parasitic drain through Fuse 9 "backup" 2001 Civic EX
I have continuous 185 mA drain in the "backup" circuit. The drain starts at about 225 mA then after about 20 seconds it drops to steady 184-185 mA. When I pull the under-dash radio fuse the current drops to about 181 mA. when I pull the 10A fuse from circuit 9 in the under hood fuse box the drain drops to less than 1 mA. There are a lot of things on this circuit. How can I figure out which is causing the battery killing drain?
Old May 25, 2015
GolNat's Avatar
Prelude Owner
Re: Parasitic drain through Fuse 9 "backup" 2001 Civic EX
Any aftermarket stuff on the car, like a remote start or headunit?
Any work previously done?
I would start unhooking things from that circuit untill the draw went away.
Old May 26, 2015
wankers's Avatar
Question Re: Parasitic drain through Fuse 9 "backup" 2001 Civic EX
How, where does one go about unhooking the following items which are on the circuit?
  1. Audio Unit.
  2. Data Link Connector.
  3. Gauge Assembly.
  4. Immobilizer Control Unit/Receiver.
  5. Immobilizer Indicator Light.
  6. Keyless Receiver Unit.
  7. Multiplex Control Unit.
  8. Security Control Unit.
  9. Audio Unit
Old May 26, 2015
GolNat's Avatar
Prelude Owner
Never said it would be easy.
I would start with the Audio and then go, keyless receiver, multiplex and gauge assembly.
I would also buy one of these:
Old Aug 22, 2018
PatrickG's Avatar
PatrickG is an unknown quantity at this point
Hi, I have a 2003 Acura EL 1.7 and fuse #9 labeled (Backup) is giving me the same issue you described on your original post. Did you ever resolve the issue?
Thanks
Old Aug 22, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
that circuit is often tapped for an aftermarket backup camera. if one was ever installed by you(or installed and possibly removed by a previous owner), i'd start there.
i'm assuming backup as in reverse lights
Old Aug 22, 2018
CraigW's Avatar
Backup is for items that require constant power. Clock, radio memory etc.....
Old Jan 20, 2019
310civicEX's Avatar
310civicEX is an unknown quantity at this point
My #9 shows -0.48 with fuse in.. -0.08 with fuse out...instrument cluster,radio and cig lighter removed same results.
Threshic
Jun 18, 2022 10:46 AM
roverben
Jan 21, 2019 05:16 PM
Kevin_646
Apr 2, 2018 02:46 AM
jback2211
Aug 29, 2013 07:16 AM
Thrasher086
Feb 25, 2009 12:12 AM
