Battery Drainage
Old Aug 4, 2007
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
Battery Drainage
Ok so I went to Vegas for this past week (and lost money lol). I come back and my battery is dead completely. No lights or anything. I knew I had some sort of drain. I used a voltmeter and plugged it to my negative terminal and negative wire and was getting a reading of .37 milliamps. I did some research and a car should be around .05 to be normal. I have a big drain. So I started pulling fusing and when I pulled the Back Up fuse my volts went from .37 to .04. I found the problem but I am not sure what the fuse is doing.
I have a Viper Alarm with the Two Way Pager which is spliced into my ignition wires. When I had the fuse out the alarm still worked. I also have a sound system which is on its own 2 gauge power wire. What is the main purpose of this fuse? Do I really need it? What can be causing so much drainage? Thanks
Old Aug 4, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: Battery Drainage
To clean it up I think you're saying you have a drain of 0.37 amps or 370 milliamps. As you stated anything over about 40-50 mA is going to be too much draw. The backup fuse runs constant power to the radio, immobilizer control unit, data link connector, keyless receiver, gauges/instrument cluster, and multiplex control unit.
Since you have an aftermarket sound system I would start by checking the wht/red wire at your radio. Maybe try unplugging the radio and see if there is a change in current draw on your meter with the back up fuse in.
Old Aug 24, 2007
Ok so I decided to hold of for a little bit on checking my drainage after finding out it is the back-up fuse. Well yesterday I haven't drove the car for 2 days and to my luck the battery was dead again. Now today will be my search for the drainage on that fuse. Can someone give me pointers on what to start ripping apart that is connected into that fuse? It will help my search adventure go faster. Thanks
Old Aug 24, 2007
I think I found the problem for the drain. My Sirius unit was wired up wrong from what I believe. The red wire went to battery while the yellow went to acc when I checked the manual and it was the other way around. My drain is now .08 instead of .37. You guys think that was the problem?
Old Aug 25, 2007
80mA isn't all that bad and I'm willing to bet the Multiplex Control unit wasn't in sleep mode for that test otherwise the reading would have been even lower. You might have nailed it. If so, congrats on a successful current draw test and resolve.
Old Aug 25, 2007
Thanks for sticking with me christmaspie. I'll update this if any problem continues. I gave you a rep point for helping me out. Thanks again
Old Nov 8, 2008
gpan171a's Avatar
gpan171a is an unknown quantity at this point
Hi there,
My 2004 Civic Coupe have also drainage problem since 6 months. Alternator was
new, and the drain is corresponding to under-hood fuse #9, which is same as you. I don't know is it multiplex control module? keyless entry problem (remote for keyless entry is aftermarket) or audio??
Could share some your experience to me?
Thanks,
Gary in Toronto, Canada 2008/11/8
Old Feb 25, 2009
Originally Posted by gpan171a
Hi there,
Thanks,
Well you need to check everything that is plugged into that fuse. What I did was have a friend use a multimeter and find the fuse that has the most drain. We began unplugging my equipment and when I unplugged my Sirius box it went to the normal level. I had the wires wrong so it was on 24/7 but I couldn't tell since it was just a box. Try that out.
robjcivic
Mar 12, 2017 12:10 PM
haloway13
Nov 6, 2015 10:43 AM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
msaeger
Sep 2, 2015 08:47 AM
