8th Gen 2006 - 2011.
2009 civic acceleration jerky problem! Please help!
Old May 10, 2015
Marcus2thextrem's Avatar
Marcus2thextrem is an unknown quantity at this point
I have an automatic 2009 civic with 90k miles on it. I bought the car with about 75k miles on it. Ever since I bought it I've had problems as it goes to shift from 1st to 2nd gear. As I accelerate and it goes to shift it gets jerky for a second and then shifts. Any idea on what would cause this? Thanks in advance!
Old May 10, 2015
CraigW's Avatar
Re: 2009 civic acceleration jerky problem! Please help!
Any record of ATF maintenance being performed ??
ATF fluid look dark ??
Old May 10, 2015
Shudder...?
Change trans fluid first, use the correct Honda ATF DW-1. Simple drain and fill, about 3 quarts.
If the shudder does not go away, change the fluid again.
Change the fluid like up to 4 times.
If still present, it may need a torque converter.
usajags84
May 10, 2015 08:11 AM
rcolosi
Apr 29, 2015 07:48 PM
civic_gt
Apr 19, 2015 08:15 AM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
