Need advice for 97 HX
Old May 9, 2015
Jigee's Avatar
Jigee will become famous soon enough
Hello, new to site!
I have a 97 HX with barely under 200k on it. Couple weeks ago I took out my engine and had to send the tranny to shop for bad input shift bearing. Unfortunately it's going to take a couple more weeks before repaired and so I was wondering what I should do in the meantime. The car is old and has plenty of miles but engine runs great and doesn't leak oil. New radiator, new alternator and a couple odds and ends.. I was hoping for some advice on what I could be checking while I have the engine out. I'm not big enough with cars to know what I should also work on but I can if I know what to look for. I was thinking timing belt, water pump, maybe starter? I already have an axle boot and a motor mount to replace. I have had very random off and on misfires every 2 months or so for past 2 years but so minor I never cared. Any advice on what I should take apart and clean/change out? Thanks, I'll include a couple pix for the hell of it
ID:	87713   Click image for larger version
Old May 9, 2015
Stock 99's Avatar
Re: Need advice for 97 HX
Timing belt is supposed to be changed every 7 years or 100 000 miles. Now would be a good time if the engines out. I believe water pump is recommended at 200k miles as well. Check the condition of your motor mounts. Clutch? If it were me I would paint it just for giggles and clean/wax the engine bay while it was out too. I'd paint it something like lime green and tell everybody it was supercharged or something.
Old May 9, 2015
Jigee's Avatar
What paint do you use for that? It would have to be heat resistant. Wax the engine bay? I didn't know That was a thing ha! What about crank?
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
