Door latch problems
Old Apr 11, 2015
Killagi's Avatar
Killagi is an unknown quantity at this point
Door latch problems
I have a 1996 Honda Civic coupe where the door was stuck. So I changed the latch n it was closing n opening just fine until I **** the door n it automatically locked. I couldn't open it from inside or unlock it from inside. The only way I could open the door was from the outside with unlocking it with the key. I took off the locking actuator n still did the same thing. Then I decide to take off the bar that locks it from between the panel n it works fine but can't lock it or unlock it from the inside.
Old Apr 12, 2015
Poopies's Avatar
Super Moderator
Re: Door latch problems
Originally Posted by Killagi
I **** the door
Don't do that!
Anyway, you took off the actuator... you replaced it, then? When you disengaged the bar thing, you disabled the locking tab from allowing you to manually engage/disengage the lock.
Old Apr 12, 2015
Replace the latch assembly.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
Ezql
May 26, 2015 11:46 PM
maaronia
May 14, 2015 10:46 PM
2k2civic
Dec 10, 2001 09:22 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
