Pressure washed engine - running rough!
Old Nov 15, 2014
lancetailor's Avatar
lancetailor is an unknown quantity at this point
Hello all,
I just recently bought a 2004 Civic EX and wanting to give it a good cleaning stopped at the DIY car wash bay yesterday. I noticed they had a selection for "engine degreaser" so I sprayed down the engine and then power rinsed it all clean. On my drive home it was "bucking" and didn't have very much power and the engine light came on and was flashing. It was about a 15 minute drive home and then it sat all night and this morning I cranked it and it was still running rough with the engine light on and so I didn't drive it today. I have since read online that you should never power wash the engine without covering delicate parts....argh stupid me! Any suggestions on what I should do? Should I take it to a local mechanic or is there something I can do to get it running strong again? I really hope I didn't damage anything on the car...yikes! Please help...thanks!!
Old Nov 15, 2014
Re: Pressure washed engine - running rough!
Pull all the coils out. It sounds like you got water in the spark plug holes.
You might be able to use compressed air to get everything dried out, but then again there could be damage such as carbon tracking on the porcelain and coil boots.
Old Nov 15, 2014
Thanks ezone, I did pull the coil wires and looked at all the plugs and they seemed to be dry. I took a compressed air hose and blew it all around the engine and I now have the car parked in the garage with a fan blowing on the engine overnight....see if that helps. Really hope I didn't damage anything too bad!
Old Nov 15, 2014
Got codes?
Typical misfires cause the engine light to flash..... but pressure washing can force water into places it should never be, such as wiring connectors.
Old Nov 16, 2014
Still running rough....what's the next step? Any suggestions? I don't know what to do....should I take it to a mechanic?
Old Nov 16, 2014
Got the codes from the check engine light? That would be a starting point.
Pull spark plugs and look for signs of carbon tracking on the white outer shells?
Driving around with a poorly running engine can ruin the catalytic converter.
Old Nov 16, 2014
Tracking like this occurs on both parts, the plug and the boot. If you don't replace both at the same time, it comes right back. One can cause the other.
Once you know what the codes are, if misfire codes you can swap parts from one cylinder to another to see if the code moves with the parts or stays in the same cylinder.
If you haven't got it figured out by Monday AM, then I'd suggest take it to a pro.
Old Nov 16, 2014
Ezone, Thanks so much for the pics and the suggestions! I'm on it! I stopped by Advance Auto and they quoted me $69 for each coil which sounded a little expensive to me so I just purchased some spark plugs. I'll pull them out tonight and take a look at them and then if that is indeed the problem purchase the coils as well so I replace them both. Thanks so much!
Old Nov 16, 2014
So I just pulled all the coils off and the spark plugs out and they all look fine to me. Should I at this point bring it to a mechanic to see what the codes are showing? I'm at my wits end.
Old Nov 16, 2014
I figured you would have got water in the spark plug holes, that's real common when someone washes the engine.
Since it doesn't appear to be that.....
Finding out what the codes are is the thing to do.
That way we can know what the computer saw as wrong, no guessing.
Then figure out what to do about it....
Many auto parts stores will check codes for free, but they can't fix cars LOL
Old Nov 16, 2014
erm, did you buy the plugs without checking them first?...
parts cannon...
Old Nov 16, 2014
I'll go to the parts store tomorrow and have them check the codes. Thanks again so much for all your help!
Old Nov 16, 2014
civicloco's Avatar
civicloco is an unknown quantity at this point
When water intrudes either by pressure washer or extreme puddles ignition components are the first to suffer. Start the engine with the hood opened in a dark place. Most times you'll notice high voltage arching fireworks around components.
Old Nov 16, 2014
Get the actual code numbers in the standard OBD2 "Pxxxx" format (i.e. P1457, P0325, etc.).
The "fault descriptions" some of those parts store code readers give are only designed to sell a shopping list of parts.
Old Nov 17, 2014
mikey1's Avatar
high pressure water like that can very easily CUT hoses and wires, even in a matter of a second or two, this is going to be a nightmare to solve
Old Nov 17, 2014
Talked to my mechanic today and he said to spray WD40 into all the electrical connectors since it is a water displacement. He said also pull the coils and spray the boots with WD40. Does this sounds logical to you all?
I first took it to the CARQUEST Parts store and the guy there plugged it in to check the codes. I came up with PO300 (random, multiple misfire), PO301 (cylinder 1), PO302 (cylinder 2), PO303 (cylinder 3) and PO304 (cylinder 4).
Last edited by lancetailor; Nov 17, 2014 at 06:55 PM. Reason: further explanation needed
Old Nov 17, 2014
check the codes.
If it is still running poorly, it sounds like there's probably water still hiding in the coils.
WD40
I guess you don't have anything to lose at this point?
I'd be trying to dry it out using compressed air though.
You already checked on how much coils cost.....
Old Nov 17, 2014
I found a set of 4 coils online for $70 which is a great deal. http://www.am-autoparts.com/2004/Hon...19/373569.html
I will try the WD40 and see what happens.
Old Nov 17, 2014
dont buy them coils before you test it!!!
ezone, where's your parts cannon picture?
Old Nov 17, 2014
It's in google image search LOL
Somehow, this one made it to the top line of the google image search
Someone order an airdrop?
Airdrop from a Stealth Bomber?
I'm still wondering if the engine still runs poorly at this point.
Since this car went to hell immediately after washing the engine, I think OP is probably on the right path with the coils but he just hasn't been able to see exactly how they got water in and failed yet.
The coils in the link....10 year guarantee? How long has that company been in business? How long before they shut down and reopen under a different name?
The "AM" in our name is a short acronym for "AFTERMARKET", as in Aftermarket Auto Parts.
I LOL'd.It's almost like the O.E.M. brand from Autozone et al.
Old Nov 17, 2014
hahaha, great ones, ezone!
lancetailor, just try to find out more of the problem before shooting the parts cannon. it usually doesn't end well to your wallet.
of course ezone might be right (he usually is), but try the cheaper options indicated by him before buying parts.
Old Nov 17, 2014
Find someone with the same car you can swap parts with?
Midnight spree at the Walmart parking lot?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
Chronic_issues
May 8, 2015 05:40 PM
TAZZ
Dec 5, 2001 09:35 PM
supercivic01
South
Nov 30, 2001 11:27 AM
