Idle Issue
Old Sep 18, 2014
tunedx's Avatar
tunedx is an unknown quantity at this point
Idle Issue
Idle hangs up @ 1500rpm for few secs and then go back down to regular idle position.. Ive been told it could either be idle air controller or throttle position sensor.. I have 5 volts on + and also checked resistance on connector. I get reading but as I begin to open butterfly by hand I get ol (no reading lose connection) I compared this with another tb and it acts in same fashion. I checked further and u are supposed to continue to get a reading on other cars. Is 7th gen civic any different..
Old Sep 18, 2014
Re: Idle Issue
Sounds like you are trying to use the wrong range on the meter. Go up a range and try it again.
Old Sep 23, 2014
arrrz's Avatar
arrrz is an unknown quantity at this point
Re: Idle Issue
Was coming here to post/search about almost the exact thing.
01 EX bone stock 5 speed. 71K miles, but new to me.
Drives fine. Depress clutch, brake and come to a stop. Idles at 1500 or so for a few seconds, then drops down to 600ish. Or, coasting down a hill, taken out of gear, it will continue to idle at 1500. Not until I come to a stop for a few seconds will it drop to a normal idle speed.
Old Sep 23, 2014
Re: Idle Issue
not an engine basic performance item. moved!
The Big Dutch
Jun 9, 2015 07:49 PM
Bradel26
May 30, 2015 10:24 AM
Allecr3
May 22, 2015 01:24 PM
crowtoo
May 11, 2015 06:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
