1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Manual Driver Door Lock 1990 DX Hatch
Old Feb 24, 2014
haydeon's Avatar
haydeon is an unknown quantity at this point
I have manual locks. The driver's side door lock is a pain in the butt.
When I'm in the car, I have to hold the lock switch unlocked as I pull the handle to open the door. It won't stay unlocked. When I get out and shut the door, it locks by itself. I have locked my keys in the car a couple of times because of this, once when the car was running.
The key turns to the right to unlock, and when it's vertical it locks. You don't have to turn the key to the left to lock it.
I mostly just don't want the door to lock by itself when I get out and shut the door.
Any ideas?
Old Feb 24, 2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Manual Driver Door Lock 1990 DX Hatch
Sounds like the connecting rod is bent. Happened to me once when I had a hard time unlocking it.
Pull off the door panel and make sure the long rod from the inside latch to the door lock is straight.
Old Feb 24, 2014
haydeon's Avatar
Okay. Cool. Thank you! I'll take a look at it.
Old Feb 25, 2014
haydeon's Avatar
I took a look inside. I couldn't see any way to adjust anything. But I played around with it for a while, and it just seems like the lock was super sticky at one point in its rotation. I tried disengaging the inside lock rod and then the key lock rod to get a feel for it. It felt a little better after spraying the crap out if it with PB Blaster.
I finally just said screw it and took off both of the lock rods, so now it's permanently unlocked. I prefer to leave my doors unlocked anyway.
I also found a spare part that looks like it came from the lock???
And the seatbelt sensor cover thingy was broken off, so I glued it back on.
Old Feb 25, 2014
Originally Posted by haydeon
That spring came off the end of the lock cylinder.
It is the spring that causes the key and cylinder to return to center when you let go of the key (when all is working correctly).
HTH
Old Feb 25, 2014
haydeon's Avatar
HTH
Thanks! That's good to know. Somebody replaced the old lock, so it must have come from that.
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
