Valve Cover Grommet install w/o removing VC
Old Feb 7, 2014
beastyben1's Avatar
beastyben1 is an unknown quantity at this point
Hi all,
2001 Civic EX 150K 5spd
When the timing belt was done I had a new VC gasket set installed including spark plug tube seals and grommets. There is a great seal on the gasket and I don't wish to disturb that.
One of the grommets for the 10mm bolts is seeping a tiny bit of oil. Can that grommet be replaced without removing the valve cover? The grommet set from Rock Auto is only like $2.
Thank you in advance.
Old Feb 7, 2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: Valve Cover Grommet install w/o removing VC
Yes, they just pop out from the top. Very easy to replace.
Runner88
Mar 2, 2023 04:54 PM
Supramk3
May 11, 2015 07:55 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
