Frayed Ground Wire
Old Jan 29, 2014
KevinMCody's Avatar
KevinMCody is an unknown quantity at this point
Frayed Ground Wire
I have a 2004 Civic DX. I've noticed there's a ground wire connecting the chassis (near the top of the radiator) to the top of the engine block. The wire has a braided covering that's frayed all to heck (pictures attached).
I'm having trouble finding a DIY guide for replacing this. It looks like it should be simple enough (basically a couple bolts, just kinda hard to reach the one), but I'm not really sure what to call it to order a replacement part.
Help?
Old Jan 29, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Frayed Ground Wire
you can search for "grounding kit" and see where people have upgraded all the ground wires in the car to 4AWG or 0AWG wiring. If you aren't too concerned about it you can just get some 8AWG wire and a pair of crimp rings and make your own cable to replace it. That should be equivalent to whats there now.
Old Jan 30, 2014
CraigW's Avatar
Looks like a copper braid around a center wire.
Old Jan 30, 2014
dred's Avatar
dred is an unknown quantity at this point
I bought one at the dealer for less then 20 bux
Old Jan 30, 2014
GolNat's Avatar
Prelude Owner
Get a new one from a dealer or old one from a junk yard.
Or stop by a local audio store and have them cut a piece of cable and crimp some ends on it for you. Might be cheaper just to buy a new OE one.
Old Jan 30, 2014
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Most autoparts stores will have a section or display of battery cables. Besides the battery cables there will be ones with bolt attachments at both ends. Get one that is the same gauge or larger and same length or slightly longer.
Old Jan 30, 2014
Poopies's Avatar
Super Moderator
+1 to that. I wouldn't call it cheap but it looks good, is relatively inexpensive, and makes more sense than replacing the one part. Gearbox has a good diy that I used. https://www.civicforums.com/forums/1...t-ii-pics.html
It took me like 15 minutes to do it.
Old Mar 23, 2014
metron's Avatar
metron is an unknown quantity at this point
I was thinking of purchasing the same part, #14 in the diagram. However, shipping is a killer on such a small item. Local parts store should have some basic ground cables for less.
CABLE, SUB-GROUND Part Number: 32610-S5A-000
Old Mar 24, 2014
CraigW's Avatar
Have the dealer get it.
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
