new battery was smoking and smelling horrible
Old Dec 17, 2013
mclld's Avatar
mclld is an unknown quantity at this point
I have had some issues with my last battery dying very easy, I thought my alternator was bad. I bought a new battery two weeks ago since my old was was no good and yesterday while driving I smell a horrible smell and look under my hood and smoke was coming off the top of the new battery. In the past couple weeks both of my low beams went out and then my high beams a few days later. Yesterday I also noticed my speedometer dropped down to zero the bounced around a bit before working like normal and I also noticed the green light around the D was off then came back on. Can bad alternator overcharge a battery? The car is a 2001 Civic EX that is completely stock
Old Dec 17, 2013
crxmanpat's Avatar
Pusher Jets Rule!
crxmanpat has a spectacular aura aboutcrxmanpat has a spectacular aura about
Re: new battery was smoking and smelling horrible
I would definitely get that alternator checked out. It probably has a bad voltage regulator and is overcharging the battery. Oh, and you need a new battery again.
But I have a question, if you suspected a bad alternator to begin with, why did you just replace the battery? Any time I'm having power issues, I have both the battery and alternator checked out. Nine times out of ten it's the battery dying (summer heat in AZ is brutal on batteries), but the alternator also needs to be checked.
Old Dec 17, 2013
mclld's Avatar
I had a guy look at it and he said I had a loose connection. I had my timing belt and water pumped replaced a few weeks earlier, maybe it happened then
Old Dec 17, 2013
crxmanpat's Avatar
Pusher Jets Rule!
Loose connection on the alternator?
Old Dec 17, 2013
mclld's Avatar
Yeah I think so
Old Dec 17, 2013
crxmanpat's Avatar
Pusher Jets Rule!
OK, once you've got everything back together properly and a new battery, I'd definitely have that alternator checked out just in case. It may have been the loose wire, but maybe not. Best to have it checked to be sure.
Old Dec 17, 2013
Make SURE the alternator mounting bolts are tight. You can ruin the PCM if they are not.
Ray Darvi
Aug 18, 2015 08:25 PM
DerbyDad03
Jul 27, 2015 11:34 AM
jzhartman
22
Jul 23, 2015 10:42 PM
1khilari
Jul 9, 2015 08:12 PM
