Daytime Running lights not working anymore.
Old Nov 24, 2013
Dhillon2012's Avatar
Dhillon2012 is an unknown quantity at this point
My yellow daytime running lights dont work when I start the engine. They use to work when I started my engine but now theres nothing. It works when I turn it on through the signal. I checked for a DLR modul, but since my car is a us model it does not have one. It is a 2004 Honda Civic Lx. I checked the fuses and they look good. Any ideas?
Old Nov 25, 2013
CraigW's Avatar
Re: Daytime Running lights not working anymore.
You never had factory drl to start with.
Are you talking about the front marker/turn signal bulbs maybe ? They should come on with headlight switch dim and flash bright with signals.
Old Nov 26, 2013
If the USA spec car was imported to Canada (OP is in B.C.), wouldn't it have to have had some way for the headlights to come on automatically (DRL) whenever the car is turned on in order to comply with Canadian regulations??
I'd assume someone would wire the headlights (or park lights) to a keyed power source, if there is no DRL controller.
Old Nov 27, 2013
I had to install a DRL module, aftermarket when i was on one year assignment in canada. They on sale on canadian tire, the cheap ones, but they only power fog lights on civics...
mattdoc
Mar 14, 2017 12:10 PM
MamaBear2015
May 3, 2015 02:17 PM
ORskier
May 3, 2015 12:54 PM
Thriftmaster
Vancouver
Apr 28, 2015 06:02 AM
cazminn
Nov 9, 2001 11:18 AM
