Xmission fluid leak around dip-stick
Old Nov 3, 2013
biker275's Avatar
Old biker dude
biker275 is an unknown quantity at this point
My 2002 Honda Civic has an automatic transmission. The transmission dip-stick seems to be loose in the access tube, and transmission fluid will occasionally leak past the dip-stick. If I re-seat it the leak will stop for a couple of cays but sooner or later it will start again. This is not a gushing leak, only a few drops on the garage floor. There is no resistance to either inserting or removal of this dip-stick.
Is the transmission dip-stick supposed to have some resistance to removal similar to the engine dip-stick?
My local Honda repair shop diagnosed the problem but did not suggest a new dip stick. Maybe there was no profit in a simple dip-stick, but they usually are not hesitant to suggest a part replacement.
Old Nov 3, 2013
Re: Xmission fluid leak around dip-stick
It's supposed to fit tighter than that.
Just get a new dipstick.. It's like $12 at a dealer.
The design has been improved, and the handle loop is the clue
# 25610-PLX-003
http://www.hondaautomotiveparts.com/...EEDOMETER+GEAR
Old Nov 3, 2013
Lvmevo's Avatar
Lvmevo is an unknown quantity at this point
yes I I just replaced mine. definitely has some resistance. when pushing in and out. good luck cost me like 14 dollars.
Old Nov 4, 2013
CraigW's Avatar
Gearbox was one of the 1st to bring that improved part to light and I thank you Steve where ever you may be.
Much better fit indeed.
http://www.hondapartsnow.com/genuine...0-PLX-003.html
Old Nov 5, 2013
biker275's Avatar
Old biker dude
I did just that, seems like a secure fit. Thanks for the reply!
Old Nov 5, 2013
biker275's Avatar
Old biker dude
agreed, a secure fit with new dipstick. thanks for the reply.
Old Nov 5, 2013
biker275's Avatar
Old biker dude
# 25610-PLX-003
The pict helped a lot. The new dipstick has a slightly larger seal which will no doubt stop the occasional dripping. Thanks for the reply!
Old Nov 5, 2013
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
You're welcome. I took that picture.
Old Nov 5, 2013
^^^This.^^^
Jul 12, 2015 11:54 AM
ZILLA
Jul 5, 2015 05:24 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
