03 Civic Rear Defrost Not Working
Re: 03 Civic Rear Defrost Not Working
Leave key at II engine off and have someone cycle the defroster button several times while listening and touching the defroster relays plastic case. Listen for click from it.
Find another relay with same #s printed and swap the 2 and test.
where is the relay? In the engine compartment fuse box?
^^^ Yes, It is somewhat by itself, near the center at the rear (best I can see, don't have my 05 any longer) near a group of 6 fuses that run ___ with the front.
Should be other relays with same printed # on case to swap with.
Try your lid though it is likely faded badly.
Think I told you wrong the relay is not like others.
At least listen and touch case will attempting defroster, and remove and re-install it a couple of times then try it.
http://www.google.com/imgres?sa=X&bi...9&tx=111&ty=69
On the sedan both the power and ground side of the defroster grid run through the "antenna module" the black box under rear deck in trunk. When defroster is on you should have + voltage at the SINGLE PIN connector (black wire, but others are shown as black in the 2 pin connector also)
Much appreciate your time to help me, Mike
CarStuff
Dec 6, 2020 12:52 PM
ej8
Apr 13, 2015 06:36 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
