Clicking noises when I take off or brake
Canadian, Eh!
This has been happening for 5 years or more but it's getting progressively worse over the years. When I start going forwards, I hear a couple of clicks coming from somewhere in the front end and when I brake I get all the same sounds but in reverse.
I swapped the suspension myself but it was all aligned and set up at the dealership multiple times over the last couple of years. The springs were swapped out for Tein S-Techs and there is a camber kit on the rear but not the front. I don't notice uneven wear on the front tires.
Re: Clicking noises when I take off or brake
You coulda searched I posted this exact same thing like 3 days ago. Its right below this thread actually. Jack your car up grab the sides of your tire move it sideways any play? Up and down any play? Get back on that.
Honestly think I just found the problem though my drivers lower a arm front bushing is ripped all the way out. This would probably be the problem. Take the tire off take bolt out and use a crowbar its easy and look for any rips, mines completely ripped.
Also check where the tie rod connects to the shock and rear a arm busbing but that one is probably ok.
jordan1794
Jun 8, 2015 08:37 PM
civicns
May 8, 2015 09:49 PM
Dorval Andre
May 1, 2015 09:37 AM
