2005 honda civic door lock problem
Old Aug 10, 2013
sc2000's Avatar
sc2000 is an unknown quantity at this point
Basically, when I try to unlock or lock the door from the inside with the automatic lock it will only work on the passenger side and the bottom left door, does anybody know how I can fix the driver side and the bottom right Door to work. Much appreciated
Old Aug 11, 2013
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
Re: 2005 honda civic door lock problem
Are you trying to lock it with the driver's side door open?
Old Aug 11, 2013
sc2000's Avatar
no the door is closed
Old Aug 11, 2013
aircooledjames's Avatar
aircooledjames is an unknown quantity at this point
Sounds like the wire harness for the door lock is bad. I would check that out first. That is a pretty common problem.
Old Aug 11, 2013
rjones7755's Avatar
Sounds more like the actuator to me, but you could test the wiring harness by hooking up a volt meter to it and see if it's receiving power when you hit the lock button.
When you hit the lock button do you see or hear the drivers side lock attempting to lock? If you can then it's definitely the actuator. Mine will do the same thing occasionally. I have the part just haven't put it in yet lol
Old Aug 11, 2013
sc2000's Avatar
when I lock my doors from the inside with the automatic lock, only the passenger and bottom left door closes /open, but when I use the keyless remote, none of them opens and the passenger and bottom left door only locks with the keyless remote
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
darwin-t
Apr 18, 2015 09:29 PM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
