2005 honda civic door lock problem
Basically, when I try to unlock or lock the door from the inside with the automatic lock it will only work on the passenger side and the bottom left door, does anybody know how I can fix the driver side and the bottom right Door to work. Much appreciated
Re: 2005 honda civic door lock problem
Sounds more like the actuator to me, but you could test the wiring harness by hooking up a volt meter to it and see if it's receiving power when you hit the lock button.
When you hit the lock button do you see or hear the drivers side lock attempting to lock? If you can then it's definitely the actuator. Mine will do the same thing occasionally. I have the part just haven't put it in yet lol
when I lock my doors from the inside with the automatic lock, only the passenger and bottom left door closes /open, but when I use the keyless remote, none of them opens and the passenger and bottom left door only locks with the keyless remote
jessicakaybby
Apr 20, 2015 12:11 PM
civic_gt
Apr 19, 2015 08:15 AM
twtron
Apr 17, 2015 12:09 AM
gabrown2
Apr 11, 2015 08:22 PM
