02 lx with 05 struts?
Hello I have finishe (I thought) a engine and Trans swap fom an 05 to an 02. The struts have diferent sized mounting bolts on the bottom. should I swap the knukles and struts in from the 05 or do I need to stick with all 02 parts on the suspention?
Re: 02 lx with 05 struts?
Really, the only difference is the size of the crash bolt. I've heard of people drilling it out from 14mm to 16mm.
or use reducing washers
see previous one asking same stuff:
https://www.civicforums.com/forums/4...vic-coupe.html
link posted there does not work anymore, but just type washer in ksport site search and it should show the reducer washer.
also, in terms of STOCK struts, the 01-02 uses a 50mm strut housing and the 03-05 uses a 55mm strut housing. bitter strut, better built.
