Shifter Lights (P,R,N,D I forget the rest!)
Old Dec 15, 2012
yagelbagel's Avatar
yagelbagel is an unknown quantity at this point
Are the driving positions supposed to light up by the shifter with the letters of the gears! park gear ... Sorry for bad english =/
like at night mine do not light up but if i look at my dashboard it shows that i Am in park or drive on the dashboard but should the lights light up?please help me thanks!!! One more small question, The airconditiner **** that chooses where the vents go feet, winshield, etc. The light for that is it easy to replace?
Thanks!
Old Dec 16, 2012
mac25's Avatar
Dr Krieger of Modification
Re: Shifter Lights (P,R,N,D I forget the rest!)
yes. every letter glows and i believe there's a square that lights up around the position you select.
Old Dec 16, 2012
It's P, R, N, D, D3, and 2. Maybe.
There is a light bulb underneath the letter plate next to the shifter lever. You probably have to pull the console up to reach it.
Bulb is part #1 here: http://www.hondaautomotiveparts.com/...+LEVER+%281%29
Old Dec 16, 2012
yagelbagel's Avatar
thanks both of you! ezone have you done this before and is it easy? and how long did it take you!?
Old Dec 16, 2012
I turn wrenches for a living.
I have taken apart a zillion different things. I have probably done this before to a car like yours.
I have no idea if it will be easy for you, but it is a cakewalk for me.
I would think an average Joe can change that bulb in an hour or less, if they have the right bulb ahead of time. And have instructions, if they aren't mechanically inclined.
Old Dec 16, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
You gotta be shitting me. I didn't think there was a bulb there because I haven't seen it light in years. GTFO, I can't believe that ****. Oh well, one more small thing to repair.
Old Dec 16, 2012
Don't tell me you have to stare at the shift lever in order to pick a gear.
Old Dec 16, 2012
04 Honda Civic's Avatar
I am an idiot, and I can do it. You can too.
I replaced this bulb on my car before, its easy.
Old Dec 16, 2012
Matt_75's Avatar
Lol, no, but I like to have everything working as designed, including light bulbs I don't need or use.
Old Dec 17, 2012
CraigW's Avatar
IIRC there are 2 smaller trim parts that lift off, then the larger panel clips out. The bulb is on drives side and 1/4 turn to release socket. Bulb pulls straight out and is a common #74 bulb.
Old Dec 18, 2012
yagelbagel's Avatar
I googled the bulb! and Now im wondering what color bulb would I need? or can i choose and single color?
Old Dec 18, 2012
The original bulb was clear.
Old Jan 5, 2013
yagelbagel's Avatar
Hey, I wanted to thank everyone for the replies! Tonight I finally got this done it was a slight pain in the *** though. A buddy of mine gave me this link it worked great! ( http://www.ledautomotive.com/guide.php?id_cms=35 )
The problem I had was when i got the bulb number 74 it was slightly too big, like the light would flash on and stuff so I pried the prongs along the side more so the connection would stay good and some how my brother managed to keep it in the notch thing! and then a new problem! when I went to plug it back into the plastic circle it kept knocking off, I got tired of it and we just drilled through the other side for more room for the slightly bigger bulb and now it works again!
Ma213802
May 18, 2015 07:01 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
01civicboi
Nov 23, 2001 03:02 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
StLVtec
Nov 14, 2001 09:22 PM
