Civic 2006 timebelt adjuster bolt keeps breaking
Old Nov 26, 2012
Asekunola's Avatar
Asekunola is an unknown quantity at this point
Dear all,
I got a used civic 2 years ago and it has been working fine until a month ago when it sudden stopped on the highway after a strange sound from the belt pulley system. I realized that the bolt holding the adjuster to the engine housing had broken and the pulley had eaten into the adjuster itself.
I got a new adjuster and the bolt. But eversince, I have had to change the bolt 3 times; it just keeps breaking. Anyone's got a hint on why?
Old Nov 26, 2012
Re: Civic 2006 timebelt adjuster bolt keeps breaking
Serpentine belt adjuster?
Has an Allen headed bolt that keeps breaking?
That bolt is to be torqued to 40 foot pounds.
Too tight will break it, so can too loose.
The belt routing was changed too, and requires a different belt if yours still has the old routing.
This bulletin explains it.
http://ww2.justanswer.com/uploads/yo...1514_civic.pdf
Old Nov 27, 2012
Asekunola's Avatar
Thanks.
Yes it is the Serpentine Belt Adjuster which has the Allen headed key.
I will share this with my technician and will revert as soon as it is confirmed ok.
Thanks for the info once again.
Old Nov 30, 2012
Asekunola's Avatar
Hi again,
I shared the details of the bulletin with ny technician and he followed the instruction and fixed the car of Tuesday, but to my surprise the bolt broake again this afternoon.
Any way out of this?
Old Nov 30, 2012
Tough for me to say, and I can't evaluate what is going on from where I sit.
All I can do is guess.
If someone attempted to repair the threads in the block and didn't get them perfectly straight, this could happen (We aren't supposed to repair THOSE threads because of this issue, it might need a block replacement if this happens).
If ANY part of the mess isn't perfectly straight and square (hole, bolt, mounting pad, tensioner), this could happen.
If the old belt routing is used, this could happen.
If the belt is the wrong size, this could happen.
If your mechanic isn't properly torquing the bolt, this could happen.
It is only about 3 or 4 simple pieces that must be assembled together properly. If any part isn't perfect.........you get what you got.
Take your pick.
Maybe have a dealer check it out.
Old Dec 12, 2012
speedy25's Avatar
speedy25 is an unknown quantity at this point
Something else is wrong besides the bolt that keeps breaking. Your tech is overlooking the real problem. Unfortunately I cant fix it over the internet, so you have to find someone with some smarts. The problem should have been addressed for good when the second bolt broke.
-SP
Old Feb 10, 2021
Rotimi Oshin's Avatar
Rotimi Oshin is an unknown quantity at this point
-SP
pls can anyone help on the
Is adjuster bolt breaking. This the forth time this happening to my car and I am frustrated and confused already. Pls I need your advice and help now pls.
Old Feb 22, 2021
https://www.civicforums.com/forums/1...ml#post4625260
pmanftw
Apr 30, 2020 05:51 PM
nordic
Feb 15, 2016 01:14 PM
mark2w1
Feb 11, 2013 05:11 PM
wetpinkpants
Nov 1, 2010 01:50 PM
wetpinkpants
Aug 12, 2010 01:45 AM
