Need answers, mostly on camber
In the next week or two i am getting acura rsx type s struts and shocks which should lowee my car 2.25 to 2.5 inches, im sure the front will be able to be adjusted and ill need to get rsx tie rod ends, as for the rear, i will hav.e to trim the lower bushing, and i also need to know which rear camber kits will give me enough adjustment to have it aligned correctly. Just need yo make sure i gotbmy stuff in order.
Thanks guys
Thanks guys
Re: Need answers, mostly on camber
Hold on, first off, stock rsx struts arnt going to make you car lower. Unless you are putting aftermarket springs on there.
Second, the rsx struts arnt built that much better than our stock ones and will definitely NOT handle a 2.25" drop. You will blow them out.
Third, why do you have to trim the lower bushing? Arnt you just installing struts? Where ate you getting your info?
And finally, to answer your question, any rear camber kit will work. The rsx and 7th gen civics are interchangeable. (ksport, spc, ingalls, etc)
Ok so I just read your other thread. From what i understand you are getting your friends setup, But stock rsx struts sill still not last for that low of a drop
But I guess if they're free then they're free right?
Whats your current suspension setup?
Lower bushing are bigger if i aint mistaken, and idk if theyre stock or not and yeah my buddy has em on his rsx and he got then from ome of ny other friends so they are lasting and havent blown didnt tell me what springs are on it but itll lower my car just over 2 inches and ill fir sure hve to get rsx tie rod ends right?
i don't see the point of replacing stock struts with stock struts not to mention the rsx is heavier and has stiffer spring rates then spending money on tie rods and alignment to be left with blown rsx shocks.i could see if it was a full aftermarket suspension setup. it just seems like a giant waste of time and money. i would rather buy some koni yellow inserts and used ground control sleeves.
Like i said idk if they are factory or not but i do know they aremt blown and they have bnn on 2 different cars my friends have the extra $ for coils i dont lol
doesn't matter your missing the bigger picture when those struts eventually blow and they will blow your going to have to spend more money replacing them when you could have just saved a little money for something better. like i said you can find used ground control sleeves for cheap. do things rite the first time.
I understand you, but if struts and shocks arent factory then they might not blow, im trying to look on the optimistic side of getting them for free, all ill be buying is the camber kit, i can install them for free and get a free alignment, oh and my friend works at oreillys he told me he would hook me up with some moog tie rod ends
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Dave Brabant
20
Oct 6, 2015 12:44 AM
Islesfan
Sep 29, 2015 03:42 AM
