Throttle response problem 07 SI
Old Jun 20, 2012
SpencerW93's Avatar
SpencerW93 is an unknown quantity at this point
Hey guys I have an 07 Civic Si and i have a minor accelerating issue. The problem mostly happens when i am in traffic. My car feels like its going to stall when i am balancing the clutch at 1000-1500 rpms which shouldnt happen. Or if i rev it in nuetral it will hesitate and then rev. This problem only happens sometimes and mostly in stop and go traffic. Any ideas on what this problem is?
Old Jun 20, 2012
Re: Throttle response problem 07 SI
well the throttle pedal is computer controled (no cable) so yes there will be a small lag when pressing it. i believe there is a company that has a solution to this issue. but if you have idle issues it could be the IAC valve is just dirty (the sensor bolted to the throttle body with coolant lines feeding it) and not able to respond fast enough so the idle drops down for a second.
DouglasTheGreat
May 27, 2015 11:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
tkcne
Apr 18, 2015 02:33 AM
1stcivic
Nov 18, 2001 09:17 PM
3rdcivic
Oct 21, 2001 01:26 PM
