2 for one special
Old Jun 12, 2012
sdaugh7261's Avatar
sdaugh7261 is an unknown quantity at this point
2 for one special
So I have a 2001 Honda Civic LX, I carry alot of tools in the trunk and it's starting to droop in the rear. So, shocks or coils? What do I need to get the *** end up to take the 300Ilbs?
Also Got a 2001 honda civic lx with a 4 speed auto, the trans just went out on it and I can't find a replacement anywhere near Tacoma. I don't wanna spend more that $400 for it and have a friend that can swap it. But I have no clue wtf the transmission model is....at lease with my ford I know its a AOD whatever model.
Also , the Honda is the base engine, SOHC non-vtec, someone said I should bolt a '03 transmission up to it instead, is this transmission compatible? is it just a bolt on and go?
Old Jun 12, 2012
sdaugh7261's Avatar
Re: 2 for one special
really, nobody?
Old Jun 12, 2012
anibis's Avatar
anibis will become famous soon enoughanibis will become famous soon enough
Any 01-05 automatic trans will work, I'd stick with an LX trans but an EX would work too, the only difference is the EX has shorter gear ratios so the RPM's run a little higher, most noticeable on the freeway.
Can't help you with the other problem, shocks wouldn't do anything though, you need stiffer springs that don't lower the car.
Old Jun 12, 2012
fstlilhonda's Avatar
fstlilhonda is an unknown quantity at this point
upgrade the shocks. factory only rated like 200lbs aftermarket are ushally over 300
OptimisticWay
46
Oct 15, 2015 02:16 PM
ChrisHandHonda
26
Sep 25, 2015 11:28 PM
MamaBear2015
Sep 4, 2015 09:04 PM
muniorbust
33
Aug 31, 2015 08:59 PM
califcamper
Jul 21, 2015 10:34 PM
