1st Gen 1972 - July 1979
2nd Gen 1979 - 1983
3rd Gen 1984 - 1987
4th Gen 1987 - 1991
5th Gen 1992 - 1995
Battery Draining
Old May 19, 2012
D16z6's Avatar
New To honda, Not to the strip.
D16z6 is an unknown quantity at this point
Battery Draining
After sitting over night I went out to open my door and battery was dead. (shaved door handles, electronic poppers) After 2 hours got the hood up and pulled the battery. It was 4 years old so I went and bought a new one. Installed it and everything was good. Started it up moved the car about ten feet. I left it running and pulled the ground off the battery and car still ran. So alternator is working as it should. Shut it off, made sure head lights, interior light was off and all looked good. Came back 3 hours later, battery was DEAD.
Any thoughts to where I should start looking?
1992 Civic EX
Old May 19, 2012
Re: Battery Draining
I'd be looking at some sort of backup system so you can still get in the car easily after the battery is dead.
My truck has shaved locks, I have a hotwire terminal in front for a dead battery, along with a hidden waterproof switch wired to the unlock relays.
For the drain on the battery, a low range inductive ammeter is my best friend, along with wiring diagrams and a systematic method of tracking down the drain.
Old May 21, 2012
D16z6's Avatar
Thanks for the help! Ya spare positive cable definitely in the future. As far as the problem I noticed my brake lights staying on after charging the battery again. Odd enough it wasnt a bad switch but a rubber nipple on the brake pedal had deteriorated into pieces. So a nut and bolt took care of the problem.
Old May 21, 2012
Brake lights? Really?
That's an odd one for me to see. I don't normally see cars that old though.
Glad you found it.
SimpleUser
Apr 24, 2021 02:54 AM
mcollins
Electrical
Jul 27, 2015 10:59 PM
Q-Bert
Jul 19, 2015 09:09 PM
Jul 12, 2015 11:54 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
