New head unit no music??
Old May 1, 2012
e-teckk's Avatar
e-teckk will become famous soon enough
So I have just recently installed a new head unit so I can plug in an aux cable and listen to my iPhone when I feel like it. Ok so its not a new head unit, it was from a buddy of mines. So before the install, my radio worked fine and his worked fine (with the head unit in).....transfer the head unit to my car and radio DOESNT WORK!!!! Its not picking up a signal because when you press the seek button the stations just keep going and going and going.
ANY SUGGESTIONS??? What went wrong??
Kind of sucks having to ALWAYS plug in an iphone or play a cd.
Old May 1, 2012
The Andrew's Avatar
The Andrew is an unknown quantity at this point
Re: New head unit no music??
sounds like your antenna is not plugged in
Old May 2, 2012
electric130's Avatar
If you have a coupe, did u connect the powered antenna amp?
Old May 2, 2012
e-teckk's Avatar
I plugged in the antenna....now Im doubting if I pushed it all the way in but I'm pretty sure I did.
Old May 2, 2012
e-teckk's Avatar
Yeah I have a coupe, whats the powered antenna amp?
I remember seeing a blue wire from the radio harness labeled "power antenna", where does that plug into? probably the solution to my problem.
Old May 2, 2012
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
nope thats for if you have a car with an antenna that pops out retracts when you turn your car on and off. we dont have those though so you just leave that wire disconnected.
Old May 2, 2012
i wasn't talking about a motorized antenna. i'm well aware that the antenna is embedded in the rear glass. coupes have an antenna amplifier in the rear pillar. sedans do not. coupes need to have the blue aftermarket amp power wire connected to the stock antenna power harness for the amp, and thus the radio reception, to work.
Old May 2, 2012
just search "coupe antenna" in the 7th gen section and you'll see this has been covered many, many times.
EDIT: just found this thread. looks like this is when I found out about it 5 years ago:
https://www.civicforums.com/forums/2...o-dilemma.html
has wiring diagrams too.
Old May 2, 2012
e-teckk's Avatar
Thanks!!
Ok so from the look of things I have to plug that power antenna wire that I saw on my HU to a yellow/green wire; so after my 8 papers I have to write I'll go check inside to see if I can find that yellow/green wire and connect the two. I'm getting a little confused because there is a lot of talk about the "C-Pillar"? I'm not good with this electrical stuff I just thought all I had to do was match the wires from my HU to the wires on the harness I bought that connects the HU to the car. ughhhh lol if I remember correctly I thought I connected all the wires together, the only ones left over were from the HU. I'll have to go check.....
Old May 26, 2012
e-teckk's Avatar
So guys!! Quick!! I need help!!
There is no green yellow wire on the harness I bought for my HU ....there is however a left over blue wire and left over orange white wire....how can I tell what is what???
Old May 26, 2012
e-teckk's Avatar
I figured out which one it was but the radio still doesn't work, like the antenna still does not pick anything up
edp22
Jan 27, 2002 02:51 PM
oblivious9
Jan 25, 2002 10:28 PM
bobbyd
Jan 7, 2002 01:31 PM
Slow2k1Civic
Jan 1, 2002 06:51 PM
noodles01
Dec 28, 2001 09:07 AM
