Interesting radio dilemma
Old May 7, 2007
Eskimo10's Avatar
Eskimo10 is an unknown quantity at this point
I've done some searching and I haven't seen many results for this. I guess maybe people don't have the same problem. I installed a Sony Explode head unit into a friends 2001 Civic. The only problem is that the radio stations don't pick up very well while it sits in the spot. Like if I pull it out and tilt it just the slightest bit it works perfectly fine, but if I slide it back so it sits flush with the rest of the car it becomes staticy and doesn't pick up stations very well. I was wondering if anybody else had any problems similar to this, and what y'all did (if anything) to fix it.
Also I switched around HU's and tried my sony in her car and her sony in my car, they both work fine in my car, but not in hers. I don't know whats up.
Old May 7, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Interesting radio dilemma
Maybe her car used to belong to 50 Cent and has armour plating all around. Phone Will Castro and ask him if he knows anything about a 7th gen Civic.
Old May 7, 2007
rednek's Avatar
rednek is an unknown quantity at this point
I had that issue also, but with my Alpine. I think it may just be a bad antenna connection. I wound up making sure to really push the two ends of the antenna wire together and wrapping the connection with some electrical tape and its been working fine for a few months now.
Old May 7, 2007
cato1978's Avatar
cato1978 is an unknown quantity at this point
Definitely sounds like a bad antenna connection since it's picking up signal while it is outside of the casing.
Old May 7, 2007
Eskimo10's Avatar
Haha I kind of like the 50cent idea lol.
what do you mean by antenna connections? The wire with the headphone looking thing on the end of it? Or is there something else that should be connected? Like a colored wire?
Old May 7, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Does she have a coupe?
Old May 7, 2007
Eskimo10's Avatar
yea she does
Old May 7, 2007
The sony deck (likely) has three extra blue wires on it. A dark blue/white for amp turn on, a dark blue for antenna turn on, and a light blue for muting or something like that.
Try hooking the dark blue antenna turn on wire from the sony harness up to the yellow/green wire in the honda harness. That should turn on the antenna amplifier.
Old May 7, 2007
Eskimo10's Avatar
Well the Sony HU only has two blue extra wires, they both have a positive charge coming from them, IE to turn something on like an amp (as one if for the amp) and there is also an orange wire left over, which is for the illumination. So I should take the blue wire with the black stripe or w/e and hook it up to the yellow/green honda wire?
Old May 7, 2007
Yup, solid blue on the sony to the yellow/green on the honda side.
Old May 7, 2007
Eskimo10's Avatar
Ah ok, I thought something was missing but her wires weren't labeled like they were in mine, I should have known lol
Old May 7, 2007
rednek's Avatar
Yeah, the headphone looking thing, but it looks like you may have found a better solution...
Old May 11, 2007
electric130's Avatar
is this only for coupes? or will it work for sedans too? is there an amp for sedans?
Old May 12, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
ya i think the coupes have an antenna amplifier and sedans dont, so sedans dont have to worry about it.
Old May 12, 2007
i am pretty sure sedans have it too, or you would barely get any fm reception, not enough to even listen to radio, mostly static. all those window glass antennas need a booster its just builtin somewhere else. its not a power antenna per-say, but you still need to wire it like one.
Old May 12, 2007
So what's the deal, did you ever get a resolution on this?
The coupes have an antenna amplifier, the sedans do not. It looks like the Si has the turn on wire for it but it isn't the same as the coupe. I have no idea as to the reasoning behind it all. Feel free to take a look at the wiring if you like.
ID:	71057   Click image for larger version
ID:	71058   Click image for larger version
Old May 12, 2007
metalviper's Avatar
^^ where do u get the wiring diagrams??
Old May 12, 2007
That's just how I roll, lol. I've got access to some fun resources.
Old May 12, 2007
metalviper's Avatar
well in that case would u be able to get me the wiring diagram to the heater controls in the bezel by any chance??
Old May 12, 2007
well when i had the power antenna wire disconnected in my sedan i got barely AM reception, almost no FM. hooked it up and the FM sounds like a cd pretty much. so dik, there has to be something. and im not talking about the actual antenna plug, i mean the wire in the harness for power antenna.
ps. honda also has an electrical manual, i got mine off ebay and its just as worth it as the huge service manual.
Old May 12, 2007
What color was the wire on the car side that corresponded with the one you had to hook up for reception?
The multiple antenna amplifier applications has confused me for a while, I'm wondering if maybe you're right and some sedans do have it.
Old May 12, 2007
i'm also interested in this as my radio reception sucks compared to the stock HU. i've got XM now, so it's not a big deal, but i'd still like better radio reception when i need it.
Old May 12, 2007
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
radio sucks anyway, you are doing her a favor.
get Sirius.
Old May 12, 2007
Originally Posted by DannyK35
get Sirius.
i'd be surprized if Sirius is around for too much longer since XM bought them out. XM rules!
Old May 12, 2007
i thought they were merging no? i dont care for sat radio, i think FM has better quality and really having tried both i got tired of the programming in a week. and the quality was terrible like 56kbps mp3. i installed that deck a while ago, not sure but on the deck it had a wire labeled power ant. and i hooked it to a matching wire in the stock harness. idk, maybe it didnt lead anywhere.but reception is amazing for the most part. also i live in farm land so theres no buildings to block signal. but it sounds really good, i just dont listen to radio so it doesnt matter anyway. i have an alpine deck too which i think is one of the better tuners. my old pioneer 940 didnt do as well.
Old May 12, 2007
i'm going to be looking into HD radio soon. XM's not bad, but it's not as clear as FM or CD. the "power ant" wire is typically to send power to retractable/motorized antennas. some older accords have the retractable antennas (i replaced one for a friend), as do many other cars. so i think that's what it's for since the antenna extends when you turn the power on and retracts when you turn the power off. just like an amp turn on wire.
Old May 12, 2007
finally someone believes me lol. everyone else is like what sat radio the quality is so good bla bla. trying to justify the cost they pay for crap. idk, maybe, just maybe on a stock crappy system you might not be able to hear the difference. i dont have a great system either but yea it still noticable.
Old May 12, 2007
2002civicLX2002's Avatar
The only Wyoming Redneck on here
2002civicLX2002 will become famous soon enough2002civicLX2002 will become famous soon enough
personally i like my XM, but i also live in the middle of nowhere and only get two radio stations. country and mexican. so XM is really good for me. but i thougth i heard someone talking about an antenna booster in the vics in the c pillar. popped a panel out and it was right there. no?
Old Jul 31, 2011
2002ExCivic's Avatar
2002ExCivic has a spectacular aura about2002ExCivic has a spectacular aura about
so what no resolution huh
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
jpat21
Sep 3, 2015 11:32 PM
hatch90
Sep 3, 2015 08:45 AM
msaeger
Sep 2, 2015 08:47 AM
