check engine light
Old Mar 3, 2012
EnVDatChink's Avatar
EnVDatChink is an unknown quantity at this point
check engine light
i recently installed a cold air intake that i got from a buddy at a used car dealer. the intake is made for my specific civic, which is a 2008 civic lx coupe straight drive. after a day of running the intake my car would shut off while i was driving and idles slightly lower than usual. after the check engine light came on i checked the code and got a po171 which would be lean air bank 1. i checked the pipe fpr any holes i double checked all the rubber hoses and everything looks to be properly installed. i really dont want to take it off and put the old one back on. anyone have any thoughts or suggestions?
Old Mar 3, 2012
GolNat's Avatar
Prelude Owner
Re: check engine light
Try disconnecting the battery to reset the ECU. Leave the negative terminal off for a couple of minutes then put it back on and drive it.
Old Mar 3, 2012
The MAF sensor is either contaminated with oil or debris, or it can't handle wild temperature swings from hot/cold air.
OR there is a leak between the MAF and the throttle body.
Just because the CAI is "designed to fit" does not mean it is "designed to work properly".
Take out the MAF sensor and inspect it for bugs.
Spray out the sensing elements with brake parts cleaner, hope it was caused by too much oil in the air filter.
Reinstall the factory breather box and all of its tubing.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
