screaching sound
screaching sound
hello i have a 2004 civic lx and there is a loud screaching sound from the engine at random times. I am pretty sure it has something to do with the pulleys because if i accelerate then it changes the sound and eventually it stops. I replaced the belts over the summer so they are new. What could be the problem?
Thanks!
Thanks!
Re: screaching sound
i have to ask this just to make sure, though if you did the belts you're probabley not this new, lol.
could it be your brakes? those deffinitally make a screeching sound that goes away when they're not in us (ei: accelerating), it's a safety feature to let you knew when you need new ones.
Does it happen typically when the car is still cold? If so, belts are one of the few things that actually contract when they warm up.. Since these cars have manual adjustments, when you originally did the belts they could have stretched and need to be readjusted. If none of these fit you may have to get someone to press on the gas while you look around and try to pinpoint the noise.
Yeap, first check the deflection. I normally just find the middle point of the longest section between the pulleys and try twisting them there. If they twist/turn more than 90 degrees give or take they need tightened. Make sure ya check both the serpentine and the individual power steering belt.
Okay cool thanks a lot! I will have to try it tomorrow because I have to write a paper now :/
okay so i tightened the belts the one one loose and so far it hasn't made a sound! Thanks
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
accelerate, brakes, civic, fix, honda, making, noise, press, random, screaching, screeching, screetches, sound, time, transmission
