screaching sound
Old Feb 6, 2012
sean2012's Avatar
sean2012 is an unknown quantity at this point
screaching sound
hello i have a 2004 civic lx and there is a loud screaching sound from the engine at random times. I am pretty sure it has something to do with the pulleys because if i accelerate then it changes the sound and eventually it stops. I replaced the belts over the summer so they are new. What could be the problem?
Thanks!
Old Feb 6, 2012
mac25's Avatar
Dr Krieger of Modification
Re: screaching sound
i have to ask this just to make sure, though if you did the belts you're probabley not this new, lol.
could it be your brakes? those deffinitally make a screeching sound that goes away when they're not in us (ei: accelerating), it's a safety feature to let you knew when you need new ones.
Old Feb 6, 2012
sean2012's Avatar
Hey lol thanks for the post but no it's not the brakes because it will do it when sitting in my driveway should have clarified that.
Old Feb 6, 2012
SlimRisk's Avatar
Busy Speeding!!
SlimRisk is a jewel in the roughSlimRisk is a jewel in the roughSlimRisk is a jewel in the rough
Could ou upload a video of some sort? And is it high pitched?
Old Feb 6, 2012
toucansam333's Avatar
toucansam333 is an unknown quantity at this point
Does it happen typically when the car is still cold? If so, belts are one of the few things that actually contract when they warm up.. Since these cars have manual adjustments, when you originally did the belts they could have stretched and need to be readjusted. If none of these fit you may have to get someone to press on the gas while you look around and try to pinpoint the noise.
Old Feb 6, 2012
sean2012's Avatar
yes I can try and get a video of it and yes it is high pitched.
It does usually happen when its cold, so should I try to tighten the belts?
Old Feb 6, 2012
Yeap, first check the deflection. I normally just find the middle point of the longest section between the pulleys and try twisting them there. If they twist/turn more than 90 degrees give or take they need tightened. Make sure ya check both the serpentine and the individual power steering belt.
Old Feb 6, 2012
sean2012's Avatar
Okay cool thanks a lot! I will have to try it tomorrow because I have to write a paper now :/
okay so i tightened the belts the one one loose and so far it hasn't made a sound! Thanks
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
