Tale of Two Engine Mounts
Old Dec 30, 2011
DesertCivic's Avatar
DesertCivic will become famous soon enough
After many months of troubling chassis vibration in my 04 DX Coupe I finally solved the mystery. If you are experiencing a severe vibration at start up and during idle, and you drive a coupe, you might find this to be your problem too. Here is what I found...
There are two different left side engine mounts, one for the coupe and one for the sedan. When I had my timing belt changed at a local shop, they installed a replacement mount from Westar (pn 9016). The Westar mount does not differentiate for coupe or sedan. Turns out this part doesn't work well on the coupe.
After several weeks of troubleshooting, including changing the three other mounts (which were all in various states of degradation, the front mount completely shot), cleaning the IAC and TB, and considering more extreme measures, I finally did a simple check of the left side mount. The check consisted of loosening the bracket screws (engine supported by jack) and starting the engine. The vibe was completely gone. I then ordered the OE coupe mount, installed it, and the vibe issue was remedied (I know, I know....always use OEM).
In the photo below you can see the difference between the sedan and coupe mount (green lines, coupe mount has the taller profile). The issue with the sedan mount is that the shorter profile allows the L shaped mounting bracket to rest on the chassis, transferring all of the engine vibration directly to the chasis.
Old Dec 30, 2011
MindBomber's Avatar
Live for the Twisties
Re: Tale of Two Engine Mounts
Excellent post and information, thanks
Old Dec 30, 2011
04 Honda Civic's Avatar
For motor mounts on ANY make or model I reccomend OEM. Most if not all OE spec engine mounts are made in china. You know what that means, and if you dont... THEY ARE JUNK.
Old Dec 30, 2011
SSMCivicCoupe's Avatar
SSMCivicCoupe will become famous soon enough
Where are the engine mounts located? Im a noob to this since i just bought my civic a couple months ago.
Old Dec 30, 2011
There are four mounts, one near the fan belts, one on the other side, one in front down low (usually always broken), and one that is at the back (remove air box to see it and it is a b*** to replace). Use search function for more info. As 04 HC says, use OEM. After market mounts are also not sized right for installation and you will run into this problem at the worst possible moment. If you need more info, please PM me.
Old Dec 30, 2011
great info - anothe unknown detail unveiled.
good to know it's solved
Old Dec 31, 2011
j_dock69's Avatar
j_dock69 will become famous soon enough
do you have oem part numbers for these different mounts? might be useful
Old Dec 31, 2011
From Majestic Honda... Sedan: 50821-S5A-A07..... Coupe: 50827-S5A-003
Old Dec 31, 2011
j_dock69's Avatar
weird, wonder why they'd be different, coupe and sedan front end is pretty much the same, no?
Old Dec 31, 2011
nuff said
Old Jan 15, 2012
bhut2180's Avatar
bhut2180 is an unknown quantity at this point
I have been having this horrible shaking since I changed out all my engine mounts. I bought my car after an accident, so I thought I'd just bought one with a bent frame. Low and beyond after 3 months of moaning over my bad purchase, I come along this page and my constant shaking is SOLVED all because I bought the wrong engine mount. YOu are on my list of favorite people for 2012!!!
Thanks incredibly soo!!!
Old Feb 17, 2012
mikereynolds9's Avatar
mikereynolds9 is an unknown quantity at this point
Im in the same boat right now. I had my timing belt replaced last June and they replaced the left side mount to. Since then I've had to take it back to the shop because of the loud vibration that keeps coming back. They first time they said the mount became loose and turned causing a loud chattering. Now they say the mount keeps breaking because the other mounts are degrading causing more pressure on the good one causing it to break. I dont know wether or not to call bs on that. Im going to call and see were they got there replacement part From. Also I'm going to try and push them to pay it to be done at the dealership because of a few other various problems I've had at this shop.
Old Feb 19, 2012
BlueEM2's Avatar
Whachya lookin at?
This is awesome awesome information to know... Hopefully we can all remember it.
Old Mar 14, 2022
SOG's Avatar
SOG
SOG is an unknown quantity at this point
As the driver of an EX Coupe, I found this 10-year-old thread incredibly useful.
In case anyone else comes across it, please know that 50827-S5A-003 has been discontinued by Honda.
Old Mar 14, 2022
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
I bought one from the junkyard that was OEM and it did the trick. I also got a new one from one of the honda parts outlets. I replaced all my mounts with OEM and the car is smooth as butter.
mikemc422
Aug 9, 2018 05:41 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
streetglower123
Apr 12, 2015 10:56 AM
CivicHAR
Jan 4, 2002 09:17 AM
