97 civic lx CEL
Old Sep 26, 2011
mack19318's Avatar
mack19318 is an unknown quantity at this point
97 civic lx CEL
only when raining does my CEL come on, and the codes are always cylinder misfire for cylinders 1 and 2.
i have replaced spark plugs, spark plug wires, distributor,and distributor cap.
i can drive around for months when its not raining out and the CEL wont come on but within the first 2 hrs of driving when its raining the CEL will come on.
i have looked at the wires, and all the wire plugs and none seem to be loose or have any type of abnormal wear or and cutting or splicing.
i am thinking about maybe using a spray sealant to coat some of the connections/plugs for water proofing.
does anyone know what wires/plugs would be causing a cylinder misfire if they got wet?
or does anybody know of another reason why i get a CEL only when its raining?
Old Sep 28, 2011
lazlong's Avatar
Re: 97 civic lx CEL
Check and replace any bad ground wires. Next time it rains check for the specific code and we can go from there. Autozone will check the code for free.
Old Sep 28, 2011
mack19318's Avatar
Re: 97 civic lx CEL
ok, i need to know where some other ground wires are that could cause this problem.
i just replaced my battery ground because there where some strands of wire the where not connected and looked a bit green.
Old Sep 28, 2011
lazlong's Avatar
Re: 97 civic lx CEL
Old Sep 28, 2011
mack19318's Avatar
Re: 97 civic lx CEL
awesome pictures! this is great info! now does it matter if i go with a larger gauged wire if i replace some of these? i have lots of 8 gauge wiring and lots of 0 gauge, i am thinking the 8 gauge is what i would go with.
Old Sep 29, 2011
lazlong's Avatar
Re: 97 civic lx CEL
If I had to I would only go 1 gauge size but, if it's more than 1 size then you're gonna have to get wire anyways. Might as well get the right size.
Old Sep 29, 2011
mack19318's Avatar
Re: 97 civic lx CEL
Ok thanks!
Old Oct 1, 2011
mack19318's Avatar
Re: 97 civic lx CEL
well i think it worked! replaced all the ground wires in the pictures you posted. two of the wires where just junk but could not tell until i had taken them off, the terminals almost fell off in my hand because the wires had rusted and started to fall apart. the connections where not really grounded either. the engine bay had been painted before i bought the car and so the ground wires where just sitting on top of paint and not bare metal. last night it rained here pretty hard and i took my car out for a few hrs and no check engine light came on!
Thanks lazlong
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
rcolosi
Apr 29, 2015 07:48 PM
Fastfebur
Apr 26, 2015 11:57 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
