Illumination for buttons on 2002 Honda Civic EX sedan
Old Sep 25, 2011
Lorenzo F.'s Avatar
Lorenzo F. is an unknown quantity at this point
Hello all,
I have a 2002 Honda Civic EX Sedan.
Can someone please tell me if these buttons are supposed to be illuminated when the taillights and/or headlights are on?
* Recirculation mode button
* A/C button
* Rear defroster button
The lights that indicate whether these functions are on *do* work, but I'm specifically wondering whether all the buttons are supposed to be backlit when the taillights and/or headlights are on.
Currently in my car only the rear defroster button is backlit but the recirculation mode and a/c button are not.
thank you in advance,
Lorenzo
Old Sep 25, 2011
MindBomber's Avatar
Live for the Twisties
Re: Illumination for buttons on 2002 Honda Civic EX sedan
Yup, they're all back lit, the bulbs behind yours are likely just burnt out.
Old Sep 25, 2011
Milkey's Avatar
Milkey will become famous soon enough
Did you recently mess with your console? When I took mine apart to put in my headunit, the backlight on those stopped working but the function buttons continued to work. Might be related.
Old Sep 25, 2011
prolly burnt bulbs. there are two bulbs for those three buttons (special size twist socket you need from dealer).
Old Sep 25, 2011
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
take your car to the dealer. there was a recall on a multiplex control unit or something for my 01. they said it could cause dash lights to stop working. if it's a light follow the steps you would to remove your cd player and then you can access those buttons from the rear.
also. are those buttons pressed when your driving at night?
Old Sep 25, 2011
Lorenzo F.'s Avatar
Inifiniteblur: I couldn't find a recall issue related to this. As for whether the buttons are on at night, yes, the indicator lights do work for all three buttons when I have those functions on.
gearbox: I'll look into whether it's really a burned bulb issue, but Milky has a point...
Milky: It's interesting that you had a experience with the backlights not working when you changed your headunit. I *just* changed my headunit when I noticed that the backlights weren't working, but I cannot confirm that the backlights weren't working *before* I changed the headunit. Milky, can you explain what you did to get your backlights to work again?
Mindbomber: thanks for confirming that all 3 buttons should be backlit!
Old Sep 25, 2011
wait are all of your backlights off? the first post made it sound like only the buttons werent working. and you say the defrost light is on. that makes me 100% sure its a bulb, because the defrost icon has its own bulb, and the ac/recirc share a second bulb. i would still replace both bulbs tho since you have it all taken out and the second one will likely burn out soon.
Old Sep 25, 2011
lowlife9's Avatar
lol ow man when i installed my head unit a couple years ago i also lost those two back lights but the defrost still works.
Old Sep 26, 2011
CraigW's Avatar
On my 05 I did them all at once, really brightens it up.
If you just do one another could go soon.
Old Sep 27, 2011
MarkoPollo's Avatar
MarkoPollo is an unknown quantity at this point
Can you please share the part numbers for bulbs? Then this thread will be the sh*t.
Old Sep 27, 2011
making mods do all the work lol
bulb #12 (79609-S5A-003)
bulb #1 (39397-SA5-003)
Old Dec 10, 2011
kinda off topic, but can you get those bulbs for the climate control in blue? or is it the film that makes it red? i hate the red.
Old Dec 10, 2011
bulbs are clear, film is either green or red depending on the car. you can peel the films off the dials and buttons and have clear light, or do yellow/orange/green film and still have it be decently bright. blue and purple film prolly wont work since filament bulbs put out most of their light in the higher wavelengths like red and orange. you have to use leds for lower wavelength colors, and ofcourse the films need to be removed or hardly any light will come out.
Old Dec 11, 2011
rjones7755's Avatar
Not kidding here, the same thing happened to me after my HU install. Mine still "go out" occasionally...all i do to make them illuminate again is pound the bottom center of the console and they light up again haha ghetto i know but maybe it'll work for you!
Old Dec 11, 2011
so what kind of led's would fit in those bulb spot? like what size? and where would i find them? i know nothing about bulbs
Old Dec 11, 2011
ledautomotive.com
Old Jan 4, 2014
upnorthguy's Avatar
upnorthguy is an unknown quantity at this point
Just to add some updated info, instead of getting mugged at the dealer for OEM bulbs, for these two bulbs you can also get a working replacement from Radio Shack.
Radio Shack 12V Microlamps 2-Pack (Model #272-1092)
They are $1.99 for two bulbs. They are a smidge shorter than the factory bulb, but still fit into the plastic holder without problem. Just remove the old bulb, slide the two wires through, pull them into the same groove where the factory bulb went, trim the lead and you are set.
Old Jan 4, 2014
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
superbrightleds.com is also a good source for cheap LED stuff. I ordered some parts for making a custom tail section on my motorcycle last year. They have premade bulbs and pretty much all the parts to make any setup you want.
http://www.superbrightleds.com/cat/c...ge,5mm,18,167:
vtec92
May 4, 2017 03:20 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
jessicakaybby
Apr 20, 2015 12:11 PM
dano2005
Apr 14, 2015 01:58 AM
vino
Nov 3, 2001 11:08 PM
